Lenovo G50-70 No display .
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Hello my friends.
    Lenovo G50-70 NM-A271
    No display , only 0.350 amp taken .
    History = It comes with short , i find that Pu 1204 PWR_VGA_Core is very hot , desoldered = no short...resold another one , Lap work .
    PWR_LED# light ok ..BATT_LOW_LED# blinking because no bat...Don't react with button = can't power off...tha lap works once adapter is inserted because i desoldered the batt coin...fan don't spin too
    Impedance are OK
    Voltages are OK :
    PL 302 = Batt coil = 1.8v
    VGA :
    PL 704/705 = +VGA_CORE = 1.008v
    PL 701 = +1.05VS = 1.056v
    VRM section :
    PL 9 = CPU_CORE = 1.8v
    StepDown section :
    PL 303 = +3VALW = 3.42v
    PL 304 = +5VALW = 5.11v
    Q23 = 5Vs present
    Q24 = 3Vs present
    Bios pin 8 = 3v
    PLT_RST#= 0v !...must be 3v
    UE1
    EC_RSMRST# = 3v
    DPWROK_EC = 3v
    PCH_PWR_EN = 3v
    +3VALW_PCH = Q29 = 3v
    EC_RSMRST = 3v
    PBTN_OUT = 3.3
    PM_SLP_S3 = 3v
    PM_SLP_S4 = 3v
    PM_SLP_SUS = 3v
    EC_ADAPTER_R= PM_SLP_S5 =0v
    SYSON = 3v
    SUS_VCCP = 3v
    SUSP = 3v
    EC_VR_ON= 3v
    PCH_PWROK = 3v
    SYS_PWROK = 3v
    SUSACK# = 0.167v
    ADAPTER_ID = 0.296v -----1.386v!
    So no pltrst , no CPU_DRAMRST...
    Change Ram , dump another bios still the same...what i miss !!
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: Lenovo G50-70 No display .
    Hello...again
    Another same motherboard but different behaviour !
    Power on , only backlight fluctuation , all voltages are present , pltrst , DRAMRST also.
    +LEDVDD / +LCDVDD_CON are ok but no DISPOFF# and no INVT_PWM...no corrision and no short to GND
    Notice : the lab power on without trigger power button and no fan at all
    So i suspect bios , try another main bios + io =
    the lap power on now with button , backlight is ok , DISPOFF# and INVT_PWM got there 3 v but nothing else ...no Fan and no picture ! ad power off after a moment
    A graphic issue !! or i must check other thing
    • rediii
      h???, spurrrn
      • Mar 2018
      • 501
      • somewhere in europe
      Originally posted by lapfix
      Hello...again
      try converting to uma: https://www.youtube.com/watch?v=Qr0D2CUGuBM
      • lapfix
        • Mar 2020
        • 2764
        • my workshop
        Originally posted by rediii
        Thank Rdii , yes i try this too but same behaviour
        Q16 and RC181 aren't populated , i just remove pl704
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Bios chip located too close to SOC?? It may be due to heat applied while soldering the chip that you got INVT_PWM back. 3VS/5VS is not dropping?? This mobo has tendency of voltage drop on 5VS. So do check these points.
          • lapfix
            • Mar 2020
            • 2764
            • my workshop
            Thank you mcplslg
            3/5 VS are stable until the lap power off by himself
            +5VS_FAN / EC_FAN_SPEED = 3v present
            EC_FAN_PWM must be check by ocsillo...don't have
            I try another bios version same behaviour : only backlight , no lenovo logo consumption reach0.93 (3 digit ) and stuck there , no fluctiation , no power off
            • lapfix
              • Mar 2020
              • 2764
              • my workshop
              Try 2 method of uma enable same behaviour : only backlight , no fan spining , no picture
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Might be EC IT8586E is defective(Just a wild guess for now but deep probing it may give confirmation). At 0.93A consumption fan should rotate atleast a bit. Are you sure fan is not bad? Try disconnecting the fan and check it manually by injecting 3V on red wire and Black wire of fan to GND of your dc. Does the fan rotate?? The fan should not be connected to mb while doing this test.
                • lapfix
                  • Mar 2020
                  • 2764
                  • my workshop
                  Weired !
                  The fan doesn't rotate ...and if i power on the lap without fan same behaviour = backlight no picture !
                  is the detection of fan necessary to get picture!!!
                  ite is defective !!
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Laptop should give display irrespective of fan being connected or not.
                    Since fan is tested bad, now i'm more inclined towards a bad EC.
                    Try flashing the EC first. Usually EC wont read/write successfully if it has problem.
                    • coasterghost
                      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                      by coasterghost
                      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                      System Hardware:
                      Processor: AMD Ryzen 7 PRO 5850U
                      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                      09-08-2025, 10:46 PM
                      Lenovo 3000 Series Schematic
                      Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                      3000 C100 laptop with Braille keyboard
                      Lenovo 3000 C
                      C100, C200 - 15-inch XGA screen
                      Lenovo 3000 N
                      N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                      N500 - 15.4 inch screen.
                      Lenovo 3000 V
                      V100, V200 - 12.1-inch WXGA models
                      Lenovo 3000 G
                      G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                      10-04-2024, 06:05 AM
                      Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                      09-06-2024, 06:40 AM
                      This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                      09-06-2024, 06:06 AM
                    • derradji89
                      Need help Lenovo MIX 320-10lCR domaine name SERCOL
                      by derradji89
                      Hi everyone 🤗
                      I have a Lenovo MIX 320-10lCR computer.**
                      1. **Operating System**: Windows 10 ** Education** 64-bit.
                      2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                      3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                      4. **BIOS Chip Reflashing**: Currently,...
                      04-19-2025, 03:04 PM
