Dead gpu on HP G72 Laptop (How to switch to uma?)
  • george94
    • Oct 2021
    • 6
    • Greece
    Hi, I have an HP G72-120ev laptop with a dead gpu chip and i want to switch to cpu graphics (uma) so i can have some basic use of the laptop and not scrap it yet. I had the chip reflowed a couple of months ago but now its dead again (black screen, no post).
    I've seen a guy from youtube who shows that by removing the gpu coil the problem is solved in some cases. So my question is, does this apply on my laptop too or i have to do more technical stuff like removing the chip itself, etc.?
    Below the details of my laptop:
    HP G72-120ev with an i3-330m and 3 gb of ram
    motherboard: DA0AX1MB6F1 REV:F
    Also somewhere on the motherboard it reads AX168 with big letters.
    I atached a picture of the board too
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Dead gpu on HP G72 Laptop (How to switch to uma?)
    https://www.badcaps.net/forum/showpo...02&postcount=2
    2.1. Never reflow large BGA
    It won't fix the problem since 99% of the time it's not an contact issue between the BGA and the logic board. There's a high risk of damaging the board even further.
    If you want to confirm if an AMD/NVidia chip is bad, you can heat it up to 200°C max for a minute and a half, no flux. It'll come back to life for a short while and then die again, because it's bad. In this case it has to be replaced.
    Whole iGPU power circuit is not populated on this board + there are a lot of other small components to swap. Way too much work, just buy a replacement board (Intel) without dGPU.
    • george94
      • Oct 2021
      • 6
      • Greece
      i looked a schematic called Quanta Ax-1 propably the right one for DA0AX1MB6F1 motherboard and i saw that there are a lot of dis to uma changes that need to be done indeed.
      Also i saw too, that there is not a coil under the cpu and other components needed for the igpu, but it has intel graphics how is that possible?
      • piernov
        • Jan 2016
        • 4439
        • France
        On this board, if there is an AMD dGPU then the Intel iGPU inside the CPU is not used at all. (no switchable graphics)
        • george94
          • Oct 2021
          • 6
          • Greece
          If that's the case then i can't do anything except buy a new one
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            This mb can be converted to uma with full intel HD support. A guide was posted by me in this forum. If you can follow the guide, it should not take more then an hour to convert it. Else, you can buy a new mb .
            • george94
              • Oct 2021
              • 6
              • Greece
              Ok, so it doesn't matter that the igpu circuit below the cpu is missing? because in your instructions you dont add any of those components. I checked all 9 images.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Yes.
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  This guide permanently connects the iGPU power rail to the 1.5V rail instead, that's definitely not how I'd do it.
                  • george94
                    • Oct 2021
                    • 6
                    • Greece
                    What's the best way then?
                    • Archerz
                      • Nov 2021
                      • 5
                      • Philippines
                      i have a problem too.
                      What happend if i remove the gpu chip
                      he is like dis to uma? any tips thanks
                      • max-power
                        Dell E6540 laptop completely dead after dssasembly
                        by max-power
                        Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                        that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                        After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                        03-24-2025, 08:49 AM
                        Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                        This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                        09-06-2024, 09:30 PM
                        Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                        This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-06-2024, 08:47 AM
                      • RdeveLabs
                        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                        by RdeveLabs
                        To all the members here...
                        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                        05-05-2025, 04:59 AM
                      • ArchangelGabriel
                        Aorus 17G YD laptop, broken display, could not switch to external monitor
                        by ArchangelGabriel
                        Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
                        11-23-2023, 03:55 AM
