asus FX804gd novideo after low side mosfet short on CPU phase
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Hello.
    I have this asus FX504gd that show novideo after low side mosfet short on CPU phase. after repair laptop start normally, fans ramping by temp, but without video. I have all voltages on coils except VCC GFX phases that must not be active.
    I found that with original bios led for "aircraft mode?" is on, but with new bios this led is not on
    any hint on this? how to check if CPU was damaged?
  • RomaM65
    • Mar 2020
    • Ukraine
    Re: asus FX804gd novideo after low side mosfet short on CPU phase
    Is there an image on external sources? For example hdmi
    Perhaps what is the supply resistance vcc gfx?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3628
      • slovakia
      no internal or external video. no short
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3628
        • slovakia
        guys nobody knows what to check?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Check if there is any pulse on VCC_GFX with dso only.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3628
            • slovakia
            what is DSO ?
              • 21936
              Originally posted by ktmmotocross
              what is DSO ?
              Digital Storage Oscilloscope
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3628
                • slovakia
                thats too hard Terminus Technicus for me
                But i have no pulses on VCC GFX. CPU have only 1ohm which is too low for me. Coils and mosfets on CPU phases gets hot quickly so i think it is burned
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3628
                  • slovakia
                  guys how to flash SIO ITE FX504fd. i dont have this board in my Vertyanov Software.
                  Or have somebody Vertyanow SW with this board in it?
                  • questore
                    HP OMEN 15-ce012nh give error code 5long 3 short after CPU LOW SIDE MOSFET BURN
                    by questore
                    Hello everyone.
                    Someone brought this poor hp in.
                    All power rails had normal resistances so i turned it on. Instant power cutoff...
                    First mosfet was shorted so replaced it...
                    After that I have tryed to start since no short was on the main power rail. the CPU middle dual mosfet heated up and protection shut down the laptop.
                    After investigating i have found that when the mosftet turning on then the mostfet got instantly hot (not the CPU)
                    Removed the faulty mosfet. -> now laptop turns on CPU mildly gets hot but laptop gives the common 5 long 3 short LED...
                    08-25-2025, 10:09 AM
                  • ktmmotocross
                    acer Predator Triton 300 PT315-52 LA-J891P no cpu power after phase mosfet short
                    by ktmmotocross
                    hello.
                    have this acer Predator Triton 300 PT315-52 LA-J891P that have no cpu main power after phase mosfet short. its resistance is so low i cannot determine if it is shorted or not. can i use somethimg like load to test phase power? like remove coils and wire some resistor or wire another board cpu?
                    01-23-2023, 06:13 AM
                  • aaronkatrini
                    DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                    by aaronkatrini
                    I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                    - Put the card in my testing motherboard and start running Heaven benchmark
                    - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                    - Try to start it again and I get a slight move from the PSU fan - a clear short
                    - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                    - Put the...
                    05-18-2025, 04:18 PM
                  • dqtech
                    Asus X455L Short Mosfet
                    by dqtech
                    I got this laptop from friend with problem short 19v....when i check this 2 mosfet getting short...i remove that mosfet and confirm that mosfet is short...
                    and check that 2 capacitor PC9009 and PC9004 pad is also short...already check where that capacitor goes and came from but cannot find the main problem...please help
                    08-09-2022, 08:53 PM
                  • c_corr
                    Asus P4C800-E VRM issues
                    by c_corr
                    This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
                    This board uses mext ICs and Mosfets in VRM:
                    - ADP3180 PWM controller - in 3 phase mode
                    - ADP3418 as Modfet drivers
                    - High side Mosfets STD38NH02L (from ST)
                    - Low side Mosfets STD90NH02L
                    Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
                    I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
                    02-08-2025, 11:59 PM
