MacBook Pro 13.3 mid 2012 - a1278 - no internal display
  • EdwardGeo
    • Mar 2020
    • 109
    • Ukraine
    Hi!
    Working on repairing of MacBook Pro. The diagnostic showed that lvds connector and cable plastic was in real bad conditions, so I decided to replace both of them. But that's not solve problems. The cable and connector have good connections to display but display won't be recognized. The voltage on lcd led pins are 0.17v, the lvds clck and data are with 3.3v, the s5 pin is also 3.3v, the other pins are 0-0.1v
    What could be a problem?
  • EdwardGeo
    • Mar 2020
    • 109
    • Ukraine
    Re: MacBook Pro 13.3 mid 2012 - a1278 - no internal display
    PP3V3_LCDVDD_SW_F = 0v
    PP3V3_S0_LCD_F = 3.3V
    PPVOUT_SW_LCDBKLT = 0v
    • mon2
      • Dec 2019
      • 14679
      Which logic board # ?
      Should be
      820-2530
      820-2879
      820-2936
      820-3115 (perhaps this one for mid-2012?)
      See attached.
      1) Post the voltages @ 1 and @ 2 for the series ferrite bead (L9004) on the LVDS power rail. If the voltages are 0 volts -> power down and remove all power.
      Meter in resistance mode. Check and post the resistance to ground for the same @ 1 and @ 2 locations.
      2) Then repeat and post the voltages and resistance readings for @ 3 & @ 4 locations on the logic board.
      • EdwardGeo
        • Mar 2020
        • 109
        • Ukraine
        Should be
        820-2530
        820-2879
        820-2936
        See attached.
        Thanks for quick reply. I did stress test on replaced cable and found short on led reverse or led backlight one of wires. If press on bottom of laptop, the cable touches the bottom case. So I do think that this is engendering issue or material which are made to be easy recycled.
        Anyway if add little pressure on original cable, the 4th led return or reverse will get a short. Actually all wires isolation looks very bad. After cable disassembly I found signs of small burn.
        So I think that the dead ic that controlling backlight is controll vdd. As short already have gone, possibly replacement of the ic will solve this problem.
        Thank you, will measure voltages as you recommend
        • mon2
          • Dec 2019
          • 14679
          Confirm the logic board # when convenient but believe the backlight for the LCD will be TI # LP8550
          Arrow currently has stock of these:
          https://www.arrow.com/en/products/lp...as-instruments
          We have free international shipping. It helps, can try to drop ship it to you - to date, any address we select appears to be with free shipping - including to our suppliers in Asia. We have replaced these in the past with success on backlight cases but of course you will need to review the other raised concerns.
          If you have not done so already, from personal experience - good flux (Amtech or a good clone of it) + hot air tool at low pressure (30-35%) but high heat (500C is what we found works on our tool). Then gently nudge the IC with tweezers till it starts to dance. Finally lift the guy off the logic board.
          Coat the WLCSP backlight pads with leaded solder (low temp solder) by skimming across the pads with a blob of solder on your soldering iron tip.
          Flux again and remove the excess solder with good desoldering braid. If the braid gets stuck - DO NOT force it off else you may rip off a PCB pad = game over on the repair. Just use higher heat to melt the junction and remove the desoldering braid. Then use IPA (alcohol) to clean the pads.
          Flux again and apply the new IC. The IC is small - at least to my naked eyes (we have not purchased a soldering microscope yet) - go slow till the solder balls melt and sink into place.
          Suggest for you to source a few of these backlight ICs for service / practice.
          • piernov
            • Jan 2016
            • 4439
            • France
            As always no point in troubleshooting backlight if there is no image...
            • EdwardGeo
              • Mar 2020
              • 109
              • Ukraine
              there is no image, because there is no voltage on LVDS panel, so it cant operate.
              The short was on old cable, which crumbled under the influence of time, the voltage Vdd 3.3v which goes to panel is made by same IC as backlight.
              Waiting for replacement IC, hope that there is no other problems
              • EdwardGeo
                • Mar 2020
                • 109
                • Ukraine
                Where can i find operation sequence of lvds?
                How system making lvds working?
                • EdwardGeo
                  • Mar 2020
                  • 109
                  • Ukraine
                  What if chipset is not enable vdd for lvds?
                  That happens if S0 not talk back to chipset via I2C?
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    Yes LCD must be recognized properly by the chipset by reading EDID through DDC I2C bus before LCD power rail is enabled.
                    Also LCD power rails will be disabled anyway if lid is closed. (SMC_LID low)
                    • EdwardGeo
                      • Mar 2020
                      • 109
                      • Ukraine
                      SMC_LID = 3.3V
                      LCD_IG_PWR_EN = 0v
                      LVDS_DDC_CLK and LVDS_DDC_DAT = 3.3v
                      So possibly display died or chipset?
                      • EdwardGeo
                        • Mar 2020
                        • 109
                        • Ukraine
                        Should be
                        820-2530
                        820-2879
                        820-2936
                        See attached.
                        the board is 820-3115-B
                        PP3V3_S5_LCD = 3.3V
                        L9004 = 0 Ohm \ 0V
                        L9008 = 55 KOhm \ 0V
                        LCD_IG_PWR_EN = 0v
                        • EdwardGeo
                          • Mar 2020
                          • 109
                          • Ukraine
                          deleted
                          • mon2
                            • Dec 2019
                            • 14679
                            L9004 = 0 Ohm \ 0V
                            Ouch!!
                            Remove the LVDS screen and all power. Measure and post again the resistance to ground on L9004.
                            • EdwardGeo
                              • Mar 2020
                              • 109
                              • Ukraine
                              Ouch!!
                              Thanks for quick response.
                              I disassemble lcd and trace the ddc I2C signal, this goes to rom ic, I think that this contain edid image. I think that need to measure the clock with frequency meter. If there is no data talking then possibly the chipset dead?
                              • mon2
                                • Dec 2019
                                • 14679
                                Hi. See attached. L9004 is the power to the LCD display via pins 2 & 3 on the LCD connector.
                                Is it this ferrite bead where the resistance to ground is 0 ohms & 0 volts (when powered) ?
                                If yes, remove the LCD and check the resistance again.
                                Do you see the same resistance @ C9011? C9012 ? If yes, remove each carefully and then measure the resistance again to ground.
                                Review the trace from U9000 to this FB for the resistance. There is a short somewhere on this line.
                                • EdwardGeo
                                  • Mar 2020
                                  • 109
                                  • Ukraine
                                  Display datasheet:
                                  https://cdn.badcaps-static.com/pdfs/...9d48ed29e7.pdf
                                  Not sure, but seems the one I have
                                  • mon2
                                    • Dec 2019
                                    • 14679
                                    Ok. What is the status of the short on L9004 rail ?
                                    Remove the display and confirm the resistance to ground on L9004.
                                    • EdwardGeo
                                      • Mar 2020
                                      • 109
                                      • Ukraine
                                      L9004 to GND = 20 kOhm and goes to infinity
                                      I done I2C capture and seems the display is not sending data. But chipset is doing his job, not sure if that is correct (i do have only i2c sensors debugging experience) but add Sealogic projects. So DDC talk to lcd is present, but no answer. Tested all pin connections from Main board to LCD board, resistance are okay. Tested LCD board on short, heat - nothing...
                                      • EdwardGeo
                                        • Mar 2020
                                        • 109
                                        • Ukraine
                                        Can I force bypass edid read and power on 3.3 v to lcd vdd to check if lcd will power on?
                                        Or read eeprom with programmer to be sure that this one is working?
                                        Actually if any lvds display have same power on sequence, I can use any display to capture it and understand how that works. And replace display or if data exchange is incorrect, replace chipset
