Da0y0emb6c0 rev c no power
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hi hope somoene can guide me
    First issue was the laptop power led was just blinking , so I though maybe just a battery issue so I open up the laptop then remov the battery after that It wont turnon anymore , removing everything then tried to [lug power just consuming 8miliamp power button press nothing happen.
    I only have +3valw no +5VALW .
    CHECKING THE PU9
    pin 4 - 3.3v -
    pin37 - 2.7v
    pin 36 - 3.3v
    pin 32 - 5.8v
    pin 26 - 20v
    pin 40 - 19v
    pin 10 - 25v
    Im having a hard time to trace the PD1 that consist of +va_air and AD_AIR.
    Hope someone has a boardview and guide me please..
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Da0y0emb6c0 rev c no power
    Do you mean light at DC jack blinking?? If so look for THERMAL PROTECTION.
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      No the power button led and taking only 8 miliamp
        • 22084
        boardview - https://www.badcaps.net/forum/showthread.php?p=1074179
        Using a genuine charger to test with ? . Check AD_TYPE
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          AD_TYPE pd4 has 1.2V
          • kalilinux25
            • Mar 2018
            • 2093
            • ZAMBOANGA SIBUGAY
            PU11
            1-19V
            2-GND
            3-NC
            4-S5PWRPG - 0V
            5-NC
            6-+3vpcu- 3.3v
            7-vout - 3.3v
            8-sw-3.3v
            9-sw -3.3v
            10-bst -8.4v
            11- VCC - 5.1
            12- EN LDO - 4.9V
            13- EN - 3.2V
            14-AGND- 0V
            15-SW-3.3V
            16-SW-3.3V
            PU10-
            1-VIN-19V
            2-PGND-0V
            3-PG-0V
            4-NC-0V
            5-VOUT-0V
            6-LDO-4.9V
            7-SW-0V
            8-BST-3.3V
            9-VCC-3.6V
            10-AGND-0V
            11-EN -3.2V
            12-ENLDO - 0V
            • mon2
              • 14713
              Power down. Meter in resistance mode.
              Check and post the resistance to ground of PL16.
              • kalilinux25
                • Mar 2018
                • 2093
                • ZAMBOANGA SIBUGAY
                +VA-AIR 19V
                +VA -19V
                AD_AIR 2.7V
                PQ6
                PIN 1 -GND
                PIN 2 - AC_LED ON# 0V
                PIN3 - +5VPCU -4.9V
                PQ7
                PIN 1 -GND
                PIN 2 - MBATLED0# - 0V
                PIN3 - +5VPCU -4.9V\
                +vAD LD - 19V
                S5_ON -3.2V
                PR170 10K -
                PIN 1 -0V
                PIN2 +3VS5 -3.3V
                • kalilinux25
                  • Mar 2018
                  • 2093
                  • ZAMBOANGA SIBUGAY
                  Soc_rsmrst# - 0v
                  soc_pltrst# - 0v
                  ec_pwrok - 1.5v
                  dpwrok_ec -1.8v
                  pltrst# -0v
                  rsmrst# - 0v
                  mainon - 2.2v
                  suson -0v
                  • kalilinux25
                    • Mar 2018
                    • 2093
                    • ZAMBOANGA SIBUGAY
                    27KILOOHMS sir
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Originally posted by kalilinux25
                      Soc_rsmrst# - 0v
                      soc_pltrst# - 0v
                      ec_pwrok - 1.5v
                      dpwrok_ec -1.8v
                      pltrst# -0v
                      rsmrst# - 0v
                      mainon - 2.2v
                      suson -0v
                      IS there any point in measuring pltrst# at this stage?? RSMRST#-On some mb's it should be 3.3V before poweron but on some mb's it comes after turning on. So I'm not sure it should be 3.3v before poweron or not
                      MAINON at 2.2V doesnt looks good. So trace this signal. I beleive it should be 3.3V
                      • kalilinux25
                        • Mar 2018
                        • 2093
                        • ZAMBOANGA SIBUGAY
                        I tried to pump voltage to the 5v coil and the Ic was getting hot but I dont have a parts right now just making sure that I just only need to replace the ic?
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                          03-31-2024, 02:12 PM
                          09-06-2024, 05:59 AM
