Asus x570D got damaged when connected battery(?)
  • Dark Knight_TJ
    • Sep 2015
    • 19
    • mx
    Hi everyone !.
    I bought an Asus laptop with battery connector ripped off. Laptop was running fine with that fault. I cut battery ends to solder where they are supposed to be . Tested with multimeter Wich one was gnd. Followed connector colors also. Everything went fine . When connected to test it laptop was not Turning on anymore ,no lights of any kind . But I noticed heat coming from beneath the board . Disassembled and desoldered battery . Tested for short between gnd and positive , nothing. Located source of heat , it seems to be a Dual-Channel Synchronous DC/DC Step-Down Controller model RT8249CGQW (not sure if is correct) (2N=5G S09 markings on surface,). Tested 19v, 5 and 3.3v , only had 19v present , seems that IC is fried . My question is how was that posible ? Maybe was at fault before? AFAIK battery has no direct connection with that IC , so maybe battery charger is the main reason of that fault that damaged the RT8249CGQW, if so then I need a schematic ,which already posted in respective subforum. What do you think ?
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • code share
    Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
    by code share
    I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
    Here's what I've tried so far:
    • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
    • Booted successfully on AC power only with the battery disconnected
    • Visual inspection of the battery — no swelling, burn marks, or connector damage
    • Battery
    04-21-2025, 12:50 PM
  • dhenion
    Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
    by dhenion
    I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
    The original board was:
    ASUS X510UNR REV 3.0 A
    The replacement board is:
    ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
    It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
    01-30-2024, 01:45 PM
  • survivalbloke
    Acer Predator Helios 300 - will not power up if battery is CONNECTED
    by survivalbloke
    This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
    06-25-2025, 12:20 PM
  • rob777
    Asus TUF won’t run off battery
    by rob777
    I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
    I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
    Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
    Thanks....
    05-27-2025, 07:07 PM
