Dell E7270 NO Power, iC charging Hot
  • andresi
    • Nov 2020
    • 154
    • INDONESIA
    i have dell E7270 No power and the Ic charging is very hot,
    Pin 1 = 18.56
    Pin 2 = 1.91
    Pin 3 = 18.59
    Pin 4 = 19.05
    Pin 5 = 4.21
    Pin 6 = 2.97
    Pin 7 = 0.00
    Pin 8 = 0.00
    Pin 9 = 0.00
    Pin 10 = 0.00
    Pin 11 = 0.00
    Pin 12 = 0.00
    Pin 13 = 2.46
    Pin 14 = 0.00
    Pin 15 = 0.00
    Pin 16 = 6.95
    Pin 17 = 0.03
    Pin 18 = 0.48
    Pin 19 = 1.01
    Pin 20 = 1.01
    Pin 21 = 7.00
    Pin 22 = 0.00
    Pin 23 = 0.0
    Pin 24 = 7.00
    Pin 25 = 6.71
    Pin 26 = 1.01
    Pin 27 = 1.01
    Pin 28 = 18.98
    what should i do replace ic or anyting solution?
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Thomasraud
    Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
    by Thomasraud
    i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
    QUOTED
    -It works on charger (without battery connected-only charger)
    -It works on battery (without charger connected-only battery)
    -& it also works when plugged in battery & charger, but it's not charging the battery
    //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
    and..
    QUOTE
    The IC cannot maintain the input current level
    06-28-2022, 06:47 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
    DELL Latitude E7270 Notebook 7000 Specification for Upgrade or Repair
    This specification for the DELL Latitude E7270 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7270 boardview and E7270 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
    09-06-2024, 05:30 PM
