New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
Hello, i have a motherboard nm-a311 cannot turn on with the power blinking led when the adapter is connected, when i check the voltage everything is normal.
For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
System Hardware:
Processor: AMD Ryzen 7 PRO 5850U
Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
I have this laptop AMD Platform starting & not posting, fan spinning.
When i press power button, the board get almost immediatly 0.5A ~ and board get stuck at 0.5A with power button led blinking indefinitly.
If i stop the computer (pressing 5s power button), board stop and when i restart i get approx 0.37A ~ and
I try to reflash the bios with no luck, same result, and i try disabling onboard ram (i remove resistors accordling schematic), no more progress.
hello guys
i have a problem with lenovo X1 carbon gen 2 laptop, with motherboard code "LMQ-1MB 12298-2 48.4LY07.021"
The main problem is that when I plug in charger, the power LED indicator flashes 4 times, the fan spins for a moment then turns off again and keeps repeating, I've tried flashing the BIOS but the result is still the same
I hope someone can help me
Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
3000 C100 laptop with Braille keyboard
Lenovo 3000 C
C100, C200 - 15-inch XGA screen
Lenovo 3000 N
N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
N500 - 15.4 inch screen.
Lenovo 3000 V
V100, V200 - 12.1-inch WXGA models
Lenovo 3000 G
G400, G410, G430, G450, G455, G510, G530, G550, and G560...
