MacBook Air 13 Retina 2018 820-01521-A
  • pascable
    • Feb 2018
    • 41
    • France
    Logic board 820-01521-A
    Dear all
    When I plug in the USB tester I have 5V but I don't go to 20V so no starting.
    After examining the 5V on the logic board I have short circuits on C7675, C7676, C7677. I had the L8570 burned out, replaced it and still no start.
    I removed the IC U7650 and I still have the short-circuited, it seems to me that my problem is with the 5V but where?
    Can someone help me please.
    Looking forward to friends.
    Pascal
  • mon2
    • 14671
    Re: MacBook Air 13 Retina 2018 820-01521-A
    https://www.logi.wiki/index.php/CD3215_Bootup_Sequence
    • pascable
      • Feb 2018
      • 41
      • France
      I will study this carefully and thank you very much.
      If necessary I come back to the forum.
      See you soon
      • pascable
        • Feb 2018
        • 41
        • France
        Reading this sentence and looking at the BRD I realize that the U3200 of my 820-01521-A is the master and the U3100 the slave.
        But I have dismantled the U32OO, I ask for confirmation that I must buy a U3200 and weld it before continuing?
        https://store.rossmanngroup.com/inde...cd3215c00.html
        U3200 is the master while U3100 is the slave. The master is connected directly to the TBT ROM (U2890), while the slave (U3100) reads the TBT ROM firmware through the master (U3200). As a result, if the master (U3200) is not working properly, the slave (U3100) won't work either.
        • piernov
          • Jan 2016
          • 4439
          • France
          Why did you remove U3200? When you have an obvious problem like a short to ground on some power rail that should be fixed first.
          In any case all USB-C controllers must be present for USB-PD negotiation to work.
          • pascable
            • Feb 2018
            • 41
            • France
            Since a while ago, I reballing the U3200 and I resoldered it.
            It's good, I have the power supply on the U3200 and the U3100 but it remains at 5V.
            I agree there is a short to earth but where is it? Where to look for it?
            To smile
            PS Je n'avais vu que c'était piernov. Je suis français aussi et suis fan de vos travaux.
            • slava318
              • Aug 2018
              • 7
              • united kingdom
              Thank you!
              • envym
                by envym
                Hi everyone!
                06-27-2025, 08:54 AM
              • korben_dallas
                Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                by korben_dallas
                Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                MY QUESTION:
                I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                02-14-2024, 12:23 AM
                Apple MacBook Air 13'' Retina 2018 820-01521 Boardview
                X1032 PJJ MLB BTTF Pre-EVT2...
                10-26-2024, 02:04 AM
              • ledbylight
                M1 A2337 Macbook - No Display, likely due to logic board
                by ledbylight
                Hi all!
                This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                11-04-2024, 06:36 PM
              • robka
                MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                by robka
                my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                After that the Macbook was dead. It isn't charging anymore.
                The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                03-02-2024, 02:58 PM
