What is this chip ? Marking RE=7E
  • Ado02
    • Jul 2021
    • 100
    • United Kingdom
    Can anyone tell me the correct model number for this chip?
    It's the one with RE=7E
    Thank you..
    • 31012
    Re: What is this chip?
    what is it from? we may have schematics
      • 20782
      It could be a richtek RT6585C
      https://www.badcaps.net/forum/showpo...84&postcount=2
      Is the motherboard part number NM-C921 ? https://www.badcaps.net/forum/showthread.php?p=1052338
      • Ado02
        • Jul 2021
        • 100
        • United Kingdom
        Re: What is this chip ? Marking RE=7E
        Thank you for your replies.
        The motherboard is from a Lenovo Legion 5 - the laptop needed a screen change after being dropped. On installing the new screen then laptop would not power on. No sign of life.
        The component in question is getting very hot and looks likes it's got a burn mark.
        Please see the attached image for the motherboard model number.
        If someone has the schematic for this board please 🙏 let me know.
        Thank you
        • Ado02
          • Jul 2021
          • 100
          • United Kingdom
          That is the same problem but I would not say the screen was the problem.
          • Ado02
            • Jul 2021
            • 100
            • United Kingdom
            Could the problem be caused because the original screen was 120mhz and the replacement 144mhz?
              • 20782
              Thank you
              The motherboard part number will be silkscreened in white somewhere. When you find it use the forum search,it might be posted already,or post your request in the "Schematic Requests ONLY!" section here: https://www.badcaps.net/forum/forumdisplay.php?f=41
                • 20782
                I doubt it,it was probably caused from something shorting when dropped.The lvds cable could be damaged
                • xnRS
                  • Feb 2021
                  • 85
                  • Belarus
                  well as SMDFlea said - it 99% is Richtek RT6585C
                  Check VIN pin on chip(SMDFlea gave link to datasheet) and check other pins(IMHO LDO3 and 5 are most important as they are 3.3V and 5V) so maybe it's not chip, but it probably is
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                    by SMDFlea
                    Bad...
                    09-02-2021, 04:40 PM
                  • Troystain
                    Help EZP2023+ updated chip database for w25q256jveq?
                    by Troystain
                    Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                    I need to add w25q256jveq chip but I do not know what data should I type.
                    I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                    The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                    11-25-2024, 12:53 AM
                  • inck243
                    Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                    by inck243
                    Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                    The BIOS...
                    07-25-2024, 09:17 AM
                  • thxd43
                    Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                    by thxd43
                    Hello, first of all, excuse me, I am using the translator, English is not my native language.
                    I have a Lenovo ideapad 330S - 14IKB laptop.
                    The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                    02-23-2023, 08:37 PM
