need help with hp g62
  • amr soliman
    • Oct 2015
    • 120
    • egypt
    i have hp g62 mainboard 01013y000-388-g (PM_I_HPC_S MV_MB_V3)
    it had short with hdmi ic after replace it works for afew secon then turn off with no data after ec and main bios reprogramed it works fine but caps lock and f12 led alwayes on even when it's turned off
    i replaced th i/o but same problem
    the laptop on power supply read 0.09 amp when it off
    can any one tell me what is the problem.
    thx
  • Sephir0th
    • Oct 2020
    • 1280
    Re: need help with hp g62
    There are more BIOS bins in the WWW to try before troubleshooting the Motherboard.
    As far as i have noticed there are Boards with and without(?) Dedicated GPU. Pay Attention to this.
    FairRepair on YouTube
    • amr soliman
      • Oct 2015
      • 120
      • egypt
      this board is uma and now its working fine but caps lock and f12 led is always on
      • Sephir0th
        • Oct 2020
        • 1280
        Then it seems there is still something to do with the BIOS, Maybe it has to be done a "Clean ME", but i can't Help in this Case. I leave this Task for more experienced members Here...
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Keyboard replaced?? If yes, then check voltage at kbd connector while in off condition and see which pin gets power even in off condition. Check that pin with schematic and probe further.
          • Sametbey
            • Jan 2021
            • 229
            • Turkey
            Did you get an image after UMA ? try this file,
            Moved: https://www.badcaps.net/forum/showthread.php?p=1059028
            I'm not happy to be so strong. because it's not humanly
            • amr soliman
              • Oct 2015
              • 120
              • egypt
              this board is intel gpu
              and yes i tried whith another keyboard
              while off mode i got +V3.3S pin 32 keyboard
              • 220vdc
                Lenovo NM-D562 no V on current sensor
                by 220vdc
                Power supply
                Legion 5 pro, nm-D562 rev. 2.0, short search. Test whith power supply 20v. Fuse, first and secon mosfet (pq110-pq111) ok...mosfet pq5401 ok 20v on drain no voltage on source and gate, mosfet pq5402 no voltage at all. current sensor pr5401 R005 no volts. pl and pc around are ok. Many capacitors and pl away are shorted. How can I check if mosfet pq 5401-pq5402 are ok or not? Why resistor R005 is not after second mosfet? Grazie for help...
                06-24-2024, 12:45 PM
              • ITguy19
                Lenovo Legion Y540-17irh-pg0 motherboard charging port leads
                by ITguy19
                The pads are damaged on this Legion Y540-17irh-pg0. I do not have any warranty left w/ Lenovo. I have taken it to a local shop, and he is trying to figure out where the pads lead to so that he can create a jumper/jump to where those pads lead too and then supply power back to the port. This is the best explanation he can provide me, I am not a soldering/mobo guru. This is NOT a BV request.
                Afew questions: Is what he described possible with this motherboard?
                Does some one have another solution OTHER THAN get another board?
                See the images attached showing...
                02-22-2023, 04:56 PM
              • estabilito
                HP EliteBook 840 G4 won't power on
                by estabilito
                Hello, i have problem with HP EliteBook 840 g4, laptop was working normally but only on 1 ram slot - second was damaged so i decided to unsolder secon slot, i did it properly - no solder joints shorted - but now laptop won't start, zero reaction for clicking power on button and weird behaviour - laptop shows orange light means charging - even if there is no battery inside.
                What should i check first?
                01-18-2023, 05:41 PM
              • ubali
                Toshiba la-6841p
                by ubali
                please my laptop have a problem,when i switch it on it blinks and the fan runs for few secon then it switch off, the model no is TOSHIBA SETELLITE LA-6841P PLEASE help on how to solve this issue. And please i need its board view
                02-16-2022, 06:52 PM
              • arber1232
                Lenovo X1 Yoga problem with fan
                by arber1232
                hi every one i have e question ?i have Lenovo X1 Yoga problem with fan.when laptop turn on fan is spining and for 5 secon turn of .
                is a problem if I join pin 1 with pin 3?...
                09-10-2020, 06:45 AM
