asus gl703gs detecting short
  • prow
    • Jul 2020
    • 14
    • croatia
    I have this motherboard from the title, there is no schematic or boardview.
    When i apply the adapter nothing happens, no lights, only little buzzing noise but adapter is not going to protection mode. Later i check and on first power mosfet there is 19,3 v but later nothing (it is not opening)....Then i check again and every time i apply the adapter it will open the second power mosfet but voltage is just droping...9v...6v...3v...0v
    So, i believe the power main controller is closing power mosfets and going to protection mode because ther is a short somewhere in lower power lines?
    I checked i believe every coil and most of the current sense resistors and joints but i couldnt find anywhere short to ground.
    I have lab power supply and i was thinking to inject voltage/amper but i am not sure how and what? so can anyone help me because i am new in repairs.
    So what is obvious is that i will not inject 19volt on second power mosfet because the "protection mode" is activated for a reason and i will probably burn something.
    Can someone help me what voltage and amper should i inject and where to to find a short?
    Thank you!
  • mon2
    • Dec 2019
    • 13992
    Re: asus gl703gs detecting short
    Remove the battery (if present). Test again.
    Use your lab power supply at 19vdc and set the current limit to 1A. Use it to power the logic board to replace the adapter.
    How much current is drawn by your lab power supply?
    You can increase the current to match the adapter ratings for this logic board.
    You can apply alcohol on the mosfet and local parts. Any misting or quick evaporation of the alcohol when powered? If yes, that part is heating up.
    Post clear pix of this area of the logic board. So we can review the mosfet markings, the charger IC.
    If the mosfets are being turned on by the charger IC but fail to pass through the adapter voltage, the mosfets may be damaged. Also the charger ic may be in current limit mode based on the ILIM configuration often set by resistor voltage dividers.
    • prow
      • Jul 2020
      • 14
      • croatia
      I did remove battery before.
      I will try with lab power supply, but as i mentioned when i plug the adapter on first mosfet on drain i have 19,3V. Source is a problem...its dropping 9v, 6v, 3v, 0v....on both power mosfets. To my understanding that means that power main controller is closing source by cutting gate....?
      I did replace both mosfets but its the same.
      • mon2
        • Dec 2019
        • 13992
        Post the details (pics) of the IC linked to the DCIN mosfets. Then we can perhaps study a reference schematic from datasheets (if public) or another laptop example circuit.
        Never mind - found some details. Will post them in a few minutes...
        • mon2
          • Dec 2019
          • 13992
          more.
          Start with:
          1) voltage @ attached locations.
          • prow
            • Jul 2020
            • 14
            • croatia
            1. a/c dock in 19,6 v
            2. Ilim 0,1 v. sometimes 0,3v dropping to 0,2v
            3. acdet 2,68 v
            4. acok 5,92 v
            • mon2
              • Dec 2019
              • 13992
              The current limit value is not correct. Pin # 21 must be a higher voltage value as it sets the max current that will be allowed to be supported by this regulator. You presently have close to 0 volts so this IC will be in shutdown mode.
              Review the attached and power down:
              1) meter in resistance mode, check the resistance for the 2 resistors that create this resistor based voltage divider.
              Resistance of PR8913 ?
              Resistance of PR8914 ?
              2) meter in volts mode, check the voltage on PR8913, pin # 1.
              This must go to +3VA.
              Post the values.
              • prow
                • Jul 2020
                • 14
                • croatia
                Resistance of PR8913 ? 62 kohm
                Resistance of PR8914 ? 44 kohm
                PR8913, pin # 1. - 0 vol
                • mon2
                  • Dec 2019
                  • 13992
                  Ok.
                  1) Both resistors are of the wrong value. They should be replaced. It is possible that the resistance values are incorrect as they are in circuit vs. being removed and then measured. You can consider to carefully remove onto one pad and take their measurements again but the parts are very low cost and should be replaced.
                  Arrow has them and they ship worldwide.
                  2) The +3VA rail is not working.
                  3) Voltage on PL8702, pin # 2 ?
                  4) mosfet gate voltages for the attached test points ?
                  P_3VADSW_HG_30
                  P_3VADSW_LG_30
                  5) Voltage on PL8701, pin # 1 ?
                  • aaronkatrini
                    DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                    by aaronkatrini
                    I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                    - Put the card in my testing motherboard and start running Heaven benchmark
                    - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                    - Try to start it again and I get a slight move from the PSU fan - a clear short
                    - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                    - Put the...
                    05-18-2025, 04:18 PM
                  • jm942
                    Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                    by jm942
                    My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                    I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                    I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                    I did voltage injection on the cpu with 0.7V and i have a current...
                    07-11-2024, 05:11 AM
                  • dqtech
                    Asus X455L Short Mosfet
                    by dqtech
                    I got this laptop from friend with problem short 19v....when i check this 2 mosfet getting short...i remove that mosfet and confirm that mosfet is short...
                    and check that 2 capacitor PC9009 and PC9004 pad is also short...already check where that capacitor goes and came from but cannot find the main problem...please help
                    08-09-2022, 08:53 PM
                  • vexarvf1s
                    Acer: No power after first MOSFET no short? Looking for guidance.
                    by vexarvf1s
                    Looking for guidance in tracking down missing main power rail.
                    I have an Acer that I am working on. It runs on the battery, but does not charge. I changed the power adapter and same thing battey not charging, and continues to discharge. So I opened the computer and started looking for the problem to fix.
                    First thing I checked is if the power form the charger is getting to the mainboard. I found that 19V is going all the way to the first MOSFET. So DC jack is fine. However I do not have power past the first MOSFET.
                    So checked for voltage on the gate of the first MOSFET and...
                    05-13-2023, 07:55 AM
                  • Jane
                    How do you test MOSFET in laptops ?
                    by Jane
                    I tried to use this method:
                    Testing an N-channel MOSFET:
                    Step 1: Discharge the Gate (turn off the MOSFET)
                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                    Step 2: Charge the Gate (turn on the MOSFET)
                    Now, place the red probe on the Gate (G) and the black probe on the
                    09-27-2024, 03:31 AM
