Dell E6540 No RAM detected.
  • Andreasbest
    • Aug 2014
    • 1180
    • Hellas ( Greece )
    #61
    Re: Dell E6540 No RAM detected.
    It is greyed out when i open it, can't type of tick anything.
    In your computer is working?
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      #62
      Yes, working fine on mine. You seem to have other layers turned on as well. Maybe try disabling a few?
      • Andreasbest
        • Aug 2014
        • 1180
        • Hellas ( Greece )
        #63
        In Visibility i enabled only what you told me now, still the same. Can you please check where R23 is and upload it? it will be easier than fixing the program.
        • Spider1211
          • Oct 2019
          • 532
          • Mauritius
          #64
          There you go.
          • Andreasbest
            • Aug 2014
            • 1180
            • Hellas ( Greece )
            #65
            Unfortunately is missing and trace is solid, no cut.
            • Spider1211
              • Oct 2019
              • 532
              • Mauritius
              #66
              That's fine, R23 is supposed to be a short anyway. In this case a trace is used instead of a jumper resistor. Check the schematic, its an underline resistor.
              • Andreasbest
                • Aug 2014
                • 1180
                • Hellas ( Greece )
                #67
                So i measure voltage to the trace?
                • Spider1211
                  • Oct 2019
                  • 532
                  • Mauritius
                  #68
                  Yes, black probe on ground and red on any of the 2 sides of R23.
                  • Andreasbest
                    • Aug 2014
                    • 1180
                    • Hellas ( Greece )
                    #69
                    No voltage on position where R23 should be according to boardview.
                    0v
                    • Spider1211
                      • Oct 2019
                      • 532
                      • Mauritius
                      #70
                      You are measuring with laptop turned on, correct?
                      Check all the stage 5 signals, SIO_SLP_S5#, SIO_SLP_S4#, SIO_SLP_S3#, etc.
                      Also make a list of which signal you measured and what its voltage was (after you are done).
                      • Andreasbest
                        • Aug 2014
                        • 1180
                        • Hellas ( Greece )
                        #71
                        Just noticed there are 3.3v but only until the error occurs, then turns to 0v.
                        • Spider1211
                          • Oct 2019
                          • 532
                          • Mauritius
                          #72
                          Which error? The blinking LED thingy?
                          • Andreasbest
                            • Aug 2014
                            • 1180
                            • Hellas ( Greece )
                            #73
                            Yes exactly
                            • Spider1211
                              • Oct 2019
                              • 532
                              • Mauritius
                              #74
                              Thats ok for now, just check the rest. Keep restarting the device if needed to measure the voltage. If you get proper signal till atleast stage 7, we might be able to rule out potential PCH issue.
                              Additionally, check resistance to ground on all coils. Just in case.
                              Post your results when done.
                              • Andreasbest
                                • Aug 2014
                                • 1180
                                • Hellas ( Greece )
                                #75
                                Can you please show me PR206 location?
                                Also please tell me which version of Allegro Free Viewer you work?
                                • Spider1211
                                  • Oct 2019
                                  • 532
                                  • Mauritius
                                  #76
                                  Am using version 16.6
                                  https://www.alisaler.com/category-laptop-boardview/
                                  Try this: after setting your layers, click on "Show Element" in the upper taskbar, that should enable the "find" menu. (see attached edit from your previous post).
                                  • Andreasbest
                                    • Aug 2014
                                    • 1180
                                    • Hellas ( Greece )
                                    #77
                                    Ok got it enabled now
                                    • Andreasbest
                                      • Aug 2014
                                      • 1180
                                      • Hellas ( Greece )
                                      #78
                                      SIO_SLP_S4# @PR203 is 5V
                                      • Spider1211
                                        • Oct 2019
                                        • 532
                                        • Mauritius
                                        #79
                                        SIO_SLP_S4# has nothing to do with PR203, are you sure you are measuring the right component?
                                        • Andreasbest
                                          • Aug 2014
                                          • 1180
                                          • Hellas ( Greece )
                                          #80
                                          Correction: SIO_SLP_S4# @PR203 is 5V
                                          Also 0v for SIO_SLP_S3# @PR607 (with or without the led blink error)
                                            DELL Latitude E6540 Notebook 6000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude E6540 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E6540 boardview and E6540 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                            09-06-2024, 04:40 PM
                                            09-06-2024, 04:10 PM
                                            09-06-2024, 04:00 PM
