sony vaio svs131e22m not charging
  • nassih
    • Oct 2015
    • 276
    • morocco
    hi everyone i have sony vaio model svs131e22m start normally but charging i have verified and replace charging ic BQ725 but still no change nothing i have checked voltages on its ic:
    acn 19v
    acp 19v
    cmsrc 18.5
    acdrv 24v
    acok 3.2v
    acdet 2.6v
    iout 2.1mv
    sda 8mv scl 8m
    scl 8mv
    ilim 3mv
    batdrv 2.3v
    srn 2.3v
    srp 2.3v
    lodrv 0v
    regn 5.9v
    btst 5.8v
    hidrv 2.3v
    phase 2.3v
    vcc 19
    tanks for help
  • mon2
    • 14104
    Re: sony vaio not charging
    Attached.
      • 20781
      Have you checked DC-IN mosfets. Check srn,srp exact resistance to ground
      https://www.badcaps.net/forum/showthread.php?t=90356
      • nassih
        • Oct 2015
        • 276
        • morocco
        ok i will tell you the resistance
        • nassih
          • Oct 2015
          • 276
          • morocco
          tanks for the information
          • nassih
            • Oct 2015
            • 276
            • morocco
            Originally posted by mon2
            Attached.
            what do you means with this?have a missing rails or voltages in that pins?
            • nassih
              • Oct 2015
              • 276
              • morocco
              DC-IN mosfet ok srn,srp resistance to gnd 128K
              i have a quation SRN,SRP in the same rails?
              • mon2
                • 14104
                What is your adapter voltage ?
                acdrv 24v
                Confirm this rail. How can it be @ 24v if adapter is @ 19v ? Do not have schematics for this logic board but this does not sound to be correct.
                The other voltages that have been highlighted in my post also do not look to be correct.
                • nassih
                  • Oct 2015
                  • 276
                  • morocco
                  now:
                  SDA 3.3V
                  SCL 3.3V
                  • nassih
                    • Oct 2015
                    • 276
                    • morocco
                    her is a schematics for this chip
                    • mon2
                      • 14104
                      Re: sony vaio svs131e22m not charging
                      What is the voltage of ACDRV ?
                      • nassih
                        • Oct 2015
                        • 276
                        • morocco
                        Acdrv:24v
                        • nassih
                          • Oct 2015
                          • 276
                          • morocco
                          PS:the computer is on
                          • mon2
                            • 14104
                            OK. ACDRV voltage is correct and matches the details from the shared datasheet.
                            Confirm again:
                            1) ILIM value - this pin configures the amount of current to be supported by this charger IC
                            2) LODRV - this cannot be 0v if the charger IC is working normally.
                            3) Voltage on PHASE pin of the charger with the adapter plugged in ?
                            • nassih
                              • Oct 2015
                              • 276
                              • morocco
                              Confirm again:
                              1) ILIM to resistor 14k and 3.3v to other side of resistor
                              2) LODRV its 0v(need schematics to see where this pin coming from)
                              3)PHASE : 1.2v
                              • nassih
                                • Oct 2015
                                • 276
                                • morocco
                                in the battery socket pins i have voltages : 3.3v and 1.1v
                                • mon2
                                  • 14104
                                  1) voltage @ ILIM pin ? if @ 33mv, that is too low. Check the resistor voltage divider for this pin. It should be similar to the datasheet but the values for the resistors could be different.
                                  2) Do you see 2 nearby resistors on ILIM ? One resistor to +3v3. Another to ground. Common pin to the ILIM pin. Power down and check their resistance.
                                  • nassih
                                    • Oct 2015
                                    • 276
                                    • morocco
                                    finally its working i have the batteries led indicator little tanks to mr mon2 i have find resistor with no value in 33k
                                    • nassih
                                      • Oct 2015
                                      • 276
                                      • morocco
                                      without schematic its not easy it is necessary to take measurements and draw a diagram itself,tanks for all
                                      • nassih
                                        • Oct 2015
                                        • 276
                                        • morocco
                                        sory a big tanks to mr mon2 and all technical forum
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                        • Mrdarkstom
                                          SONY VAIO PRO PK PC8949C11N
                                          by Mrdarkstom
                                          buenos Dias me podrian quitar la contraseƱa de esta Bios SOny Vaio modelo de placa lo adjunto en foto
                                          Good morning, could you remove the password for this BIOS of the Sony Vaio motherboard model? I attach it in the photo.
                                          in English please.....
                                          11-28-2024, 09:42 AM
                                        • noipi
                                          sony vaio VJS112C11W FAN NOT WORKING
                                          by noipi
                                          I tried to check and look for the Boardview and schematic for this Sony Vaio with mb marking DA0MSAMBAG0, the problem of this sony is the fan not working or spinning, i checked the 5volts to red and yellow, black zero volts and white zero volts. i checked the fan and test to direct 4volts it is spinning. Any diagram to trace this fan not spinning. i change the new fan still not work. Any one have a boardview and schematic diagram?...
                                          05-26-2025, 09:01 PM
