Problems with my HP 14-df0016ds Notebook (black screen)
  • Issei
    • Jun 2021
    • 6
    • Argentina
    Hello, everyone! I have come to ask you to enlighten me about a problem with my HP 14-df0016ds notebook ... In an update of windows 10 in 2020 (June) the notebook was left with a black screen ... (the charging led turns on and power button but it does not start absolutely windows, nor does it let me enter the BIOS) ... I downloaded from the hp page, an update that they just did in April of this year ... so I proceeded to make a usb with the flash of the new update of the bios, to see if I could revive it ... (it gets more interesting) I press the combination of keys (windows + B) and the screen works with the image of "downloading new bios" (they appear loading files with a blue bar) ... once it is finished, a countdown appears warning that the notebook is going to restart in 10 seconds to continue the process ... and when it restarts ... the screen returns to black and nothing happens ... THE BIG QUESTION IS ... WHAT DO YOU RECOMMEND ME TO DO? I AM A LITTLE DESPERATE WITH THIS QUESTION .... I thank you very much for the space ... and if you notice that my English is horrible, it is because I am using the google translator XD
  • mon2
    • Dec 2019
    • 14667
    Re: Problems with my HP 14-df0016ds Notebook (black screen)
    When you power on - do you see any text or graphics ?
      • 21907
      Try pressing Ctrl + Alt + Del on the keyboard and see if anything happens .Hold Ctrl down,then press Alt down keeping Ctrl and Alt held down, then press Del (or Delete) once ,and let go of all keys .
      You can try pressing once on the windows key as well .
      • Issei
        • Jun 2021
        • 6
        • Argentina
        when I turn on I do not see any letters or graphics ... I only see graphics when I do the key combination (Windows + B) that the active one when I try to install a bios update from a USB ... but normally it does not do anything else to turn on the power lights ...
        • Issei
          • Jun 2021
          • 6
          • Argentina
          nope....not work
          • mon2
            • Dec 2019
            • 14667
            Sounds like you just need to apply the proper BIOS for your unit.
            Can you confirm that you have downloaded the proper BIOS firmware for this computer ?
            Download a fresh copy and attempt to reflash it again. I think you are in a stuck mode where the logic board is unable to boot till the BIOS is corrected.
            If you feel you have the proper BIOS - contact HP to ask about this issue. A suggestion is to consider an older version of the firmware but best to ask HP if this is recommended. I believe that most BIOS firmware is bullet-proof to apply but best to be safe to ask for their advice.
            In attempting to download the BIOS tool from the following HP website - it is an executable that has to run on Windows. This is a catch-22 if you are unable to boot from Windows.
            Is this understanding correct ?
            Share a pic of what you can see upon boot for a review. Is it a USB BIOS update tool of some sort ?
            • Issei
              • Jun 2021
              • 6
              • Argentina
              Unfortunately, from my experience HP is very bad in customer service in Argentina...(By the way, the bios comes from the official Hp website and is specific to my notebook model) ... that's why I try to see if here xD can help me .... in the usb with the update of the bios, it generated a file type ".doc" with information about the process ... I'll put them below, to see what you think ... because I don't understand much about the process ...
              EFI HP BIOS Update 3.9.4.0 Started
              2018-01-01 16:44:48 [L]> System ID: Type
              2018-01-01 16:44:48 Failed Loading EFI_HP_BIOS_IMAGE_INTERFACE_PROTOCOL2_GUID(Not Found)
              2018-01-01 16:44:48 HP BIOS Image Interface Protocol Version 2.0
              2018-01-01 16:44:48 [L]> EFI_HP_BATTERY_CONTROL_PROTOCOL_2010 is present.
              2018-01-01 16:44:48 Type 11 1 tables
              2018-01-01 16:44:48 Type (000000000000000Bh), Len (0000000000000005h), Handle (000000000000001Dh), String count (0000000000000009h)
              2018-01-01 16:44:48 HPBATDET: Environment Variable not found.
              2018-01-01 16:44:48 BATDET: Date 7//26//2018
              2018-01-01 16:44:48 BATDET: 0
              2018-01-01 16:44:48 [L]> BATDET: HP
              2018-01-01 16:44:48 [L]> Found 1 Absolute Pointer Protocol(s)
              2018-01-01 16:44:49 [L]> SetBestGopMode to 0: 1366x768
              2018-01-01 16:44:49 [L]> 0 UART device path node found.
              2018-01-01 16:44:49 All Required Protocols Located
              2018-01-01 16:44:49 HpBiosUpdate.Mode = 4
              2018-01-01 16:44:49 WRITE_BB = 0
              2018-01-01 16:44:49 Current Directory = HP\BIOSUpdate\
              2018-01-01 16:44:49 [L]> System ID: Type
              2018-01-01 16:44:49 SMBIOS Init Success
              2018-01-01 16:44:49 SystemFamily = 2
              2018-01-01 16:44:49 [L]> PlatformLang reported as en-US.
              2018-01-01 16:44:49 [L]> Language Selected is currently (eng).
              2018-01-01 16:44:49 Starting BIOS Update Process
              2018-01-01 16:44:49 Setting BIOS Update Token
              2018-01-01 16:44:49 Getting BIOS Detail Information
              2018-01-01 16:44:49 IsBiosSixDigits = 0
              2018-01-01 16:44:49 BIOS Returned BiosID '0849E'
              2018-01-01 16:44:49 QueryImageDetail: 4K Block Size detected.
              2018-01-01 16:44:49 Skip Addresses:
              2018-01-01 16:44:49 Entry 0: Address 0x3C5000: Size: 0x1000
              2018-01-01 16:44:49 Entry 1: Address 0x3C7000: Size: 0x24000
              2018-01-01 16:44:49 Entry 2: Address 0x655000: Size: 0x40000
              2018-01-01 16:44:49 Entry 3: Address 0x77F000: Size: 0x81000
              2018-01-01 16:44:49 Loading BIOS Image
              2018-01-01 16:44:49 File name constructed: HP\BIOS\Current\0849E.bin
              2018-01-01 16:44:50 Reading New BIOS Image HP\BIOS\Current\0849E.bin
              2018-01-01 16:44:50 Getting BIOS version from file image
              2018-01-01 16:44:50 Bios Version = F.63
              2018-01-01 16:44:50 Verifying AC or Battery Power Status
              2018-01-01 16:44:50 Verifying Binary match
              2018-01-01 16:44:50 Loading Signature File
              2018-01-01 16:44:50 Failed Reading BIOS Signature File HP\BIOS\Current\0849E.sig
              2018-01-01 16:44:50 Failed Reading .sig file. (Not Found)
              2018-01-01 16:44:51 Bios Verify Signature Success (Success)
              2018-01-01 16:44:51 Loading Password File if required
              2018-01-01 16:44:51 BIOS Password not required.
              2018-01-01 16:44:51 Writing BIOS Image
              2018-01-01 16:48:38 Verifying Written BIOS Image
              2018-01-01 16:48:38 VerifyImage: 4K Block Size detected.
              2018-01-01 16:48:53 Skipping Verification Block 965 Address 0x00000000003C5000 Size 0x0000000000001000
              2018-01-01 16:48:53 Next BlockIndex 966, BlockAddress = 0x00000000003C6000
              2018-01-01 16:48:53 Skipping Verification Block 967 Address 0x00000000003C7000 Size 0x0000000000024000
              2018-01-01 16:48:53 Next BlockIndex 1003, BlockAddress = 0x00000000003EB000
              2018-01-01 16:49:00 Skipping Verification Block 1621 Address 0x0000000000655000 Size 0x0000000000040000
              2018-01-01 16:49:00 Next BlockIndex 1685, BlockAddress = 0x0000000000695000
              2018-01-01 16:49:02 Skipping Verification Block 1919 Address 0x000000000077F000 Size 0x0000000000081000
              2018-01-01 16:49:02 Next BlockIndex 2048, BlockAddress = 0x0000000000800000
              2018-01-01 16:49:02 Updating BIOS files
              2018-01-01 16:49:02 EfiBiosUpdateLibEntry(): Result is 0x0
              2018-01-01 16:49:02 Setting Flash Completion Status
              2018-01-01 16:49:02 BIOS Update Process Complete
              2018-01-01 16:49:02 BIOS Update Successful
              • mon2
                • Dec 2019
                • 14667
                Please confirm:
                1) You are stuck with the screen that only allows you to update your bios ?
                2) Post the full details of which download you used for this BIOS update. Which version? Filename ?
                3) Noting some issues in the posted log.
                4) I think you are not alone with this issue - or is this your post ?
                https://h30434.www3.hp.com/t5/Notebo...S/td-p/8044203
                • Issei
                  • Jun 2021
                  • 6
                  • Argentina
                  Please confirm:
                  no, that's not me ... but from what I see the same thing happens to me, but with another model of hp notebook ... now as soon as I get off work I send photos of what my notebook does ... and then about the hp bios that I download ... do you think so?
                  • mon2
                    • Dec 2019
                    • 14667
                    Wow. This is a serious issue. I just posted the same on their forum. Someone has to have a proper resolution to this fault. No one posted an update to the owner from 04-2020. That is very sad.
                    Yes, post more information.
                    Do you have a local cell phone repair shop in your area ?
                    What may be required is to use SMD (surface mount) tool like a hot air gun to remove the FLASH BIOS chip and then a low cost flashing tool to fix this fault.
                    That is pathetic if this is the resolution. We know HP very well and have supplied them with our custom hardware for over 20 years to date. However, also know that they outsource such laptop designs to suppliers in Asia with varying quality.
                    Regardless, it is their responsibility to fix this issue. Law suits are made from such cases. Apple has lost millions on such recalls and faults.
                    • mon2
                      • Dec 2019
                      • 14667
                      Ok. Just found this which is worth a try. The idea is to remove the CMOS (coin cell battery) to reset the logic board.
                      Please read the full thread here -> try it or ask any questions here -> then post your results:
                      https://h30434.www3.hp.com/t5/Notebo...e/td-p/6716008
                      • mon2
                        • Dec 2019
                        • 14667
                        Any update on your screens that you can see ?
                        HP wrote back on their forum and have asked you to review the following:
                        https://support.hp.com/in-en/document/c00042629
                        Update the BIOS manually from a USB Flash drive (outside of Windows)
                        Do update this thread with your results.
