Macbook pro Mid 2012 820-3115 No Backlight Has picture.
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    Hi again guys i have a 820-3115-B logic board that has no signs of liquid damage and is working perfectly fine. It has picture but no backlight . I already did all the basic troubleshooting so screens and backlight fuse has all been ruled out as okay.I used a working board which has backlight to compare and diagnose. And in the picture below is the only thing i notice is different. Am not so great with backlight on these boards as yet. So hoping you guys can guide me where to check next or if it's the backlight Driver that is bad and needs to be changed. I have posted a picture of the voltage on working board as u can see
    12.54V on pin 1 of D9701 and Pin 2 reads 26.49V Good Board
    12.54V on pin 1 of D9701 and Pin 2 reads 12.54V Bad Board
    So apparently it's not boosting I could be wrong.
    Bad Board
    Good Board
  • mon2
    • Dec 2019
    • 14256
    Re: Macbook pro Mid 2012 820-3115 No Backlight Has picture.
    1) post the enable voltage on pin A3
    2) often, the boost regulator ic at u9701 is replaced if the enable is ok.
    • platinumsteel
      • May 2019
      • 234
      • Trinidad&Tobago
      Ok A3_Enable pin voltage reads 3V . But when u say boost regulator at U9701.Can u kindly elaborate on it a bit ? thanks
      • mon2
        • Dec 2019
        • 14256
        U9701 is most likely defective and needs to be replaced.
        LP8550 is a part from Texas Instruments and you can source through Arrow / Digikey / Mouser / AliExpress.
        Better yet, order directly from TI :
        https://www.ti.com/store/ti/en/p/pro...e-octopart-wwe
        Order spares as they are quite small. Lots of youtube videos on topic on how to replace this part using hot air tools. See Louis Rossman or similar.
        Take notes on pin #1 of the bga package and where it is on the logic board. You will need some tacky flux for the repair.
        Kapton tape is recommended to protect the nearby parts from flying off during the repair. Use low air pressure but high heat to melt the old part. Be very patient and remove the part only when it starts to swim in the flux on its own. Then carefully use leaded solder which is low temp solder as compared to ROHS solder. Apply this solder carefully across each ball pad on the logic board. Then remove this solder carefully using resolder braid to flatten each ball pad on the logic board.
        Finally apply flux again and insert a fresh IC to solder in the new part with the hot air gun.
        Be sure to watch a few videos a few times to get the idea of the process.
        • platinumsteel
          • May 2019
          • 234
          • Trinidad&Tobago
          Okay thanks a lot for confirming my friend.I will be sure to report back once I get tru it .
          • judamex
            Active Member
            • Jan 2021
            • 183
            • Mexico
            i have the same problem, replace U9701 and now all its ok. TY
            • MtapeK
              • Sep 2020
              • 35
              • Zimbabwe
              Bad Board
              Good Board
              Hello Good Day, I'm Not Sure If im lae to respond here or you have solved your Problem For backlight On Your 820-5115 Board. But i wanted you to check if there is continuity between A5 of U9701 and {pin 2 } of D9701, if there is continuity the feedback line is working fine then the Problem might be your Backlight Driver.
              if there is no continuity make sure to run a jumper wire between A5 of U9701 and pin 2 of D9701 it will fix your Problem
              • Rezendes
                Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                by Rezendes
                Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                05-10-2024, 02:18 PM
              • korben_dallas
                Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                by korben_dallas
                Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                MY QUESTION:
                I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                02-14-2024, 12:23 AM
              • bastien
                OBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
                by bastien
                It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
                This is the new database for FlexBV
                it's optimized to work with it
                by using board ID has Default name, give us the opportunity,
                to use other diode board data with sibling board or family board
                I Merged the whole data (optimal)
                A2991 A2992 M3 -> -> 2 Entries diode data M1
                A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
                A2442 A2485 A2779...
                03-18-2025, 08:03 AM
              • envym
                MacBook Pro 2018 with Activation Lock
                by envym
                Hi everyone!
                I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                06-27-2025, 08:54 AM
              • Tr0ll
                by Tr0ll
                Original T-con:
                First replacement T-con:
                10-07-2023, 07:48 PM
