Lenovo Yoga NM-A381 Motherboard no power, wont turn
  • BumThief
    • Jun 2021
    • 6
    Hi All,
    Looking for advice on where to start and diagnose the problem to resurrect my laptop.
    I am only getting 5V on Pin 1 (PJP1) when the power is plugged in. It should be 20V.
    Laptop uses funny USB charging port. When plugged in to laptop should recognise and then USB supply 20V, otherwise default is 5V.
    I can order a new power socket or could, but how can I rule out other issues on the motherboard first?
    I have read other forums on here that is similar issue but they are a bit ahead of me in diagnosis.
    Any advice or assistance would be appreciated.
    Attached schematic and board view.
  • Sephir0th
    • Oct 2020
    • 1282
    Re: Lenovo Yoga NM-A381 Motherboard no power, wont turn
    Check your Charging Port visually and also the Port of the Adapter. I have in Mind it is a square one, yellow colour with a small Triangle (for Not accidentally Plug in another USB-Port).
    Share Pic how it Looks inside
    They're Well known for being physically damaged.
    FairRepair on YouTube
    • Francisco.s
      • 686
      • Spain
      Probably +3VL are missing due to the kbc (IT8386E-192) being in shot-circuit.
      As Sephir0th mention, the usb port from charger is probably damaged, and trough USB_ID injects 20v. to the IT8386E.
      It is a common issue in NM-A381 motherboard.
      • BumThief
        • Jun 2021
        • 6
        Hi All,
        Thank you for getting back to me, sorry for delayed reply, tried to get a better camera to take photos but they still look bad.
        Attached photos of cable and socket. I can try get better quality if need be.
        The sockets don't look too bad, there are marks from general use it seems. Nothing out of place and pins don't look damaged.
        If IT8386E-192 is short circuited, would I have to install identical one (IT8386E-1502-192)?
        Or can I use any IT8386E-XXXX-192?
        Kind regards
        • BumThief
          • Jun 2021
          • 6
          I have bought and testing a new power cord and am now getting 20V as expected.
          Laptop still wont turn on and no charging light on battery.
          Should I replace IC chip?
          I noticed PL202 getting hot, however I couldn't measure a voltage coming through. This doesn't seem right?
          • mon2
            • Dec 2019
            • 14263
            1) PL202 is a coil and under normal conditions, it will be warm / hot to the touch.
            2) If PL202 is not showing any voltage then there is a fault on that rail.
            What is the voltage reading of +5VALW ?
            3) Power down and set your meter to resistance mode (lowest scale).
            What is the readings in ohms with:
            red lead on PL202, pin # 2 with black meter lead on ground ?
            If the resistance (of +5VALW) is very low then you have a short condition on that rail that needs to be investigated. Could be a bad (shorted) cap or another condition.
            4) What are the voltage readings
            @ ACDET ?
            @ ADIN_1 ?
            @ V_CHG ?
            @ V_PATH ?
            • BumThief
              • Jun 2021
              • 6
              Hello Mon2,
              Thank you for your response.
              I fear something may have happened while testing, when I plug in charger, fans will turn on and IC gets hot very quickly. I measured and then had to step away, came back and plugged in charger and this is the case.
              I managed to get a few measurements before this happened
              There is was no 5VALW present.
              PL202 = 403 ohms
              Now when i measure it is shorted.
              ACDET = 2.6V
              ADIN_1 = 20V
              I am hesitant to try measure V_CHG and V_PATH due to issues mentioned above.
              • mon2
                • Dec 2019
                • 14263
                Which ic gets hot quickly?
                • Sametbey
                  • Jan 2021
                  • 229
                  • Turkey
                  You must be careful while measuring. Since the legs are small in materials such as a charge chip, you should use a needle-tipped probe. Measure which side the short-circuit is on by lifting the PL202 coil. After the coil, you can detect the heated part by giving a voltage starting from 1v (max 3.3V).
                  ACDET and ACOK outputs of the charging chip are important. Required for the IO chip to start.
                  I'm not happy to be so strong. because it's not humanly
                  • BumThief
                    • Jun 2021
                    • 6
                    UE1 i think it is, the IT8386E-192 CXS chip
                      Lenovo Yoga YOGA Book Hybrid (2-in-1) Book Specification for Upgrade or Repair
                      This specification for the Lenovo Yoga YOGA Book Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the YOGA Book boardview and YOGA Book schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                      09-06-2024, 08:10 AM
