MacBook air SSD not detected
  • kalzabdul
    • Sep 2020
    • 28
    • Uganda
    Hi. I have a macbook air ssd no recognized, another working ssd but all in vain.
    Any idea on how I should diagnose it?
  • mon2
    • 13996
    Re: A1466 SSD not recognised
    Can you clarify? The macbook air SSD is not recognized? You have installed a known good SSD onto this macbook air and the good SSD is still not recognized ?
    If yes, start with inspecting the SSD connector region for possible damage / corrosion.
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • bibinskii
      Macbook Pro M1 (A2338) - Not Charging but Detected and Post
      by bibinskii
      A client showed up with a Macbook Pro M1 stating that the battery doesn't get charged (no increase in percentage) but still charge. She left me with the battery 25% and still draining. The Macbook is fully functional. I checked with coconut battery and system report. Battery health shows 85% and stating normal condition, no abnormalities. When it is charging, the system says it takes 10 hour to finish charging. I went ahead to charge it for a longer period, the battery just drains (doesn't get charged).
      At first, I thought that this must be a battery issue. I went to replace the battery....
      07-22-2024, 12:22 AM
    • resistor83
      SSD MacBook Pro 2015 not recognized and gets hot
      by resistor83
      Hi everyone, a customer brought me an original Apple SSD (mz-jpv2560/0a4) from a 2015 MacBook Pro to ask me to recover the data. He told me that the computer was taken to the Apple center but that there was a problem with the motherboard and therefore it could not be repaired....
      However they removed the SSD so for try to recover data
      I tried to insert this SSD into another 2014 MacBook Pro that I had but the SSD could not be seen either from the recovery or from an operating system started from USB (BigSur or El Capitan)
      I also tried with a USB adapter but nothing
      I also...
      12-10-2023, 02:47 AM
    • tobeend
      Bypass mdm macbook m2 ventura
      by tobeend
      1. RESET MACOS WITH IPSW
      a. Power off MacBook, press and hold the power button to enter Recovery
      b. Open Disk Utility, remove Macintosh HD
      c. Reboot, connect to the network to Activate Mac.
      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
      e. Release the other keys, but keep holding the Power key for another 10 seconds
      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
      05-26-2023, 07:18 AM
    • salim5566
      Macbook A1708 EMC3164 battery not detected laptop on when power cable in
      by salim5566
      HI everyone i have strange problem i have macbook A1708 battery not detected
      i have change new battery still same, when i plug charger in to laptop it can turn on soon as i take out cable macbook turn off. anyone knows how do i solve this problem?
      thanks
      07-15-2022, 07:37 PM
