Macbook Pro Retina work only with adapter
  • nassih
    • Oct 2015
    • 280
    • morocco
    i have this macbook 2012 model A1425 motherboard 820-3462 work normal with adapter but not working with battery.its show charging and the battery has 134 cycle charge and its detected by the system.
  • nassih
    • Oct 2015
    • 280
    • morocco
    Re: Macbook Pro Retina work only with adapter
    i have this voltages without adapter in:
    PPVBAT_G3H_CONN: 11.38v
    PPVBAT_G3H_CHGR_R : 11.38v
    CHGR_PHASE :11.38v
    • nassih
      • Oct 2015
      • 280
      • morocco
      • nassih
        • Oct 2015
        • 280
        • morocco
        with adapter in i have 12,56v on PPVBAT_G3H_CHGR_R but goes to 11,38 immediately
        • mon2
          • 14662
          Battery is probably crap. It is a common issue. Check with a fresh battery from a supplier that will take it back if there is an issue.
          Remove the battery and post the same voltages.
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            What mon2 said. I recieved NEW OEM batterys with 0 cycles and they were crap. It is most def that bat.
            sigpic
            MEOWING IN THE IMPOSSIBLE UNIVERSE!
            • nassih
              • Oct 2015
              • 280
              • morocco
              ok i dont have another battery but i will check more voltages and tell you tanks for replay
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                without battery, post volts on battery connector after connect adapter.
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  Most batteries for A1425 available on the market are garbage.
                  • janceth
                    • May 2021
                    • panama
                    I have a cuestión about this MacBook.
                    the hardware of the MacBook retina 12" inch 2017 is compatible with hardware of MacBook retina 12" inch 2015
                    • azzidoqsc
                      • Jul 2021
                      • 25
                      Can you check what is the voltage of the cells ? Sometimes the laptop battery chip gets locked due to worn cells or over discharged cells (battery stored for a long period). The PFF (Permanent Failure Flag) is set and nothing can be done with that battery unless you unseal the chip and clear PFF.
                      I usually repair laptop batteries in my free time. If you want to open the battery I could guide you how to try repairing it.
