Asus x751ld rev 2.0 mosfet problem
  • NConstantinou
    • May 2017
    • 351
    • Cyprus
    Dear all
    i have the above m/b and i am facing a problem with 2 short mosfets P2003BEA.
    can i substitute with any N channel mosfet that has Vds 30v, Vgs 20v and Id=10A.
    P2003 BEA states 20mOHMS Vgs10v!
  • NConstantinou
    • May 2017
    • 351
    • Cyprus
    Re: Asus x751ld rev 2.0 mosfet problem
    IF I SUBST. WITH ap9402 WHICH IS
    Vds 30v
    Rds 18Mohms
    Id 20.6A
    Vgs 20v
    or
    M3002 mosfet
    would that be ok!
    • piernov
      • Jan 2016
      • 4439
      • France
      https://logi.wiki/index.php/User:Pie...iginal_part.3F
      • NConstantinou
        • May 2017
        • 351
        • Cyprus
        Thanks for the reply,
        Finally I have changed the mosfet with 7410.
        On ic up1589 vin is ok, enable 3.3 and 5v is ok, entrip1,2 are ok, enldo is ok but there are no outputs on coils for 3.3 and 5v. On pins 7 I have 0v and on pin 19 0.1v
        I checked with multimeter in diode mode these 2 pins and look ok.
        I checked for short, no short.
        On switch button I have 3.3v but not on pin 8 of bios.
        Do you have any suggestions.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Check Feedback resistors and powergood.
          • NConstantinou
            • May 2017
            • 351
            • Cyprus
            ok i will check resistors.
            i would like to point out something.
            i have changed 1589 ic.
            at all times pin 20 it shown short except once.
            i unsolder the ic and trace were not short nor when the the ic was install pins were touching to each other. that happen with different ic's.
            i will trace that also
            thanks
            i will come back to you
            • NConstantinou
              • May 2017
              • 351
              • Cyprus
              Asus x751ld rev 2.0 dual mosfet 6 pin
              I have the above m/b which does not have 3.3 and 5v supplies.
              Ic step down regulator seems to work ok. i have Vin, LDO3.3 and 5v,EnLDO 6v,
              Entrip1,2 ok.
              there is one dual mosfet 6 pins (very small) label NT which is getting very HOT. Is located near the RT8239B.
              testing pins 1 and 6 seems ok and 3 and 4 are ok is diode mode.
              does anyone knows what is the function of that 6 pin mosfet!
              does that preventing 3.3 and 5v to power up!
              Note: no short is shown on any coils.
                • 21962
                Re: Asus x751ld rev 2.0 dual mosfet 6 pin
                This might be the one with NT marking ,https://www.badcaps.net/forum/showpo...14&postcount=9
                The boardview will show you what its connected to https://www.badcaps.net/forum/showthread.php?t=89785
                • NConstantinou
                  • May 2017
                  • 351
                  • Cyprus
                  Ok. After investigation of m/b I found that 3
                  +3vEC and 3v vcc are shorted near the EC IC.
                  The EC ic is ite8585e.
                  Does this mean that IO is burned!
                  • lazaro.089
                    Asus Zephyrus M16 / GU603ZW problem
                    by lazaro.089
                    Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                    CPU: Core i9-12900H
                    Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                    Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                    The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                    08-26-2025, 06:33 PM
                  • AtelierRepa
                    ASUS X712JA problem
                    by AtelierRepa
                    I have a problem with the bios, let me explain.
                    With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                    I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                    My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                    The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                    06-15-2024, 04:33 AM
                  • MicroSMD Lab
                    ASUS ROG Zephyrus GPU Mosfet repeat failure
                    by MicroSMD Lab
                    The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                    I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                    01-10-2024, 06:36 AM
                  • greg1985
                    Asus dabkxmb18b0 rev.b bios problem
                    by greg1985
                    Hi. I bought a damaged Asus motherboard, model dabkxmb18b0 rev.b. The problem with the motherboard was a faulty processor.
                    I replaced the processor, but it arrived without a BIOS chip. I found one post on the forum, but my problem is
                    I don't know which chip to program, and I don't have a schematic. Does anyone know which BIOS chip models are compatible with this motherboard? If so, please let me know. Thanks.
                    10-20-2025, 11:34 AM
                  • someonenotyou
                    ASUS G513R - cannot remove MOSFET
                    by someonenotyou
                    Hi.
                    I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
                    I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
                    Of course, I did not force it, but tried to lift it up with tweezers.
                    Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
                    10-10-2025, 11:05 AM
