Dell XPS 13 - DA0D13MBCD1 how to disable onboard ram
  • maciek1221
    • Mar 2017
    • 39
    • Ooland
    do you know how to disable onboard ram on this motherboard? I have 4 beeps after power button press. Or how to check which module can be broken and take off it from the board.
    • 21917
    Re: Dell XPS 13 - DA0D13MBCD1 how to disable onboard ram
    Test voltage on PU3 pins 3 and 13 ,and test PQ26,PQ27 .Are any of the ram chips getting hot
    • maciek1221
      • Mar 2017
      • 39
      • Ooland
      PU3:
      Pin 3 - 0,7V
      Pin13 - 1,5V
      None of ram chip is hot.
      Gate and Source of PQ27 is shorted, there is continuity between them, should I replace it?
        • 21917
        Edit: pu3 pin 13 has 1.5V so pq27 must be ok . Measure Pin 20, 1.5V_SUS_PWRGD
        • maciek1221
          • Mar 2017
          • 39
          • Ooland
          On pin 20 PU3 is 3,3V
          • brotank
            Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
            by brotank
            I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
            can someone disable onboard ram from my dumped bios, please 🙏
            I tried the other bios on this forum with disabled onboard ram, but no success
            my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
            after that I officially give up 😂
            thanks for awesome jobs 😊...
            03-16-2025, 12:51 PM
          • ktmmotocross
            Dell Vostro 5590 onboard memory error - how to disable/repair it?
            by ktmmotocross
            Hello. Have this Dell Vostro 5590 K4AAG165WB-MCTD that show 2x orange+5 white led blink which is memory error. i try to search in schematic but there are no option for no onbooard memory.
            I try to edit bios by SPD removal tool 1.6 but non options work for me and laptop dont even normally start like without ram
            so how to repair this error?
            02-04-2025, 09:04 AM
          • b-slayer
            Acer A317-53 need help to disable faulty onboard ram
            by b-slayer
            Hello.
            I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
            - first one is to modify le bios to disable the onboard ram.
            - second one is to disable the onboard ram by desoldering some components on the mainboard.
            so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
            so i found that my motherboard...
            10-12-2024, 03:46 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • xloomx
            X512DK MAIN BOARD REV. 2.1 Disable Onboard RAM
            by xloomx
            Asus F512D, motherboard X512DK MAIN BOARD REV. 2.1 Hynix 4GB OnBoard, (ID0=0, ID1=0, ID2=1)
            In this case to disable onboard ram, Take out R0916 and place a 10K Resistor on R0913.
            The configuration would be for N/A:N/A , ID0=1, ID1=0, ID2=1. (Working for me with Hynix 4gb OnBoard Memory, in this case, do not touch other resistors)
            Images Attached...
            01-28-2025, 10:14 AM
