help with laptop dell DAJW8CMB8E1
  • marcelofct
    • May 2019
    • 122
    • chile
    good morning friends I hope you can help me I have this equipment and it does not turn on, I connect the charger and I have
    the 3.3v alw but not the 5v alw check the ic pu4 (RT8223PZQW)
    I do not have the entrip1 but I do have the entrip2, I assume that this is my problem to be able to activate the mosfet pq49 and pq45 according to my appreciation
    attached schematic
    please help
  • lapfix
    • Mar 2020
    • 2750
    • my workshop
    Re: help with laptop dell DAJW8CMB8E1
    Power sequence P 5/6 you must have this signal = ALW_ON to get +5V_ALW.so check this signal before
    • marcelofct
      • May 2019
      • 122
      • chile
      checked ALW_ON and it is not generated by the kbc (IT8528) if it is not generated by the kbc, should I check if it has the 3.3v vcc? sorry for my little knowledge but I'm learning
      • marcelofct
        • May 2019
        • 122
        • chile
        someone with any ideas
        • mon2
          • 14415
          As per above advice,
          1) see page 5 and follow the red circles which denote the power up sequence
          2) ALW_ON is generated by the EC - check the direction of the arrows which indicates that the EC is using an output port pin to drive the ALW_ON signal.
          3) What is the voltage reading of ALW_ON ? Place your meter in DC volts mode, then red probe on ALW_ON rail and black probe on ground.
          You can read ALW_ON @ Q32B, pin # 2.
          If this pin is not logic '1' = should be +3v3 (or close to this value) then the EC needs to be investigated.
          Confirm that the trace is not broken between the EC and Q32B, pin # 2.
          • marcelofct
            • May 2019
            • 122
            • chile
            the voltage is 0v pin 83 EC
            .-on pin 2 voltage is 0.1v
            .-the trace is ok I measured continuity
            thank for your help , i still learning
            • Sephir0th
              • Oct 2020
              • 1283
              Resistance to ground of PQ32B Pin 2?
              FairRepair on YouTube
              • mikey5791
                Dell laptop model PP24L won't start from ac adapter
                by mikey5791
                Dear all,
                Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
                But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
                03-24-2023, 09:06 PM
              • Mots06
                Old Dell E5400 Laptop ( Purchased in the year 2008)
                by Mots06
                Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
                07-19-2025, 01:56 AM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • Calidebear
                Dell 3537 laptop doesn't boot without embedded display.
                by Calidebear
                I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
                So checked the schematics to bypass this issue.
                Found something but I don't know how to read this schematics.
                Dell 3537 mobo 9982p rev 3
                Schematics attached,...
                03-29-2025, 11:37 AM
                Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                09-06-2024, 09:30 PM
