Asus X550VX rev 2 and Vram type
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Asus X550VX nvidia error 43, before replacing the graphics chip, having an identical card, I try to replace the vram. The voltage of the vram on the card is 1.35V but while this card uses Elpida W4032BABG VDD = VDDQ = 1.6V / 1.55V / 1.5V ± 3% and 1.35V ± 3% the donor card uses samsung 4KG41325FC-HC03 K memories : POD_18 (1.8V, 1.8V)
    How is it possible
    • 21971
    Re: Asus X550VX rev 2 and Vram type
    The ninth character is an F so its F:POD_15 (1.5V,1.5V)
    4KG41325FC
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      ok
      thanks but not 1.35 (dual voltage as elpida) ?
      The dc/dc is a up1565p , which provides two (fixed ?) voltages, 1.5v and 1.8 so what I didn't understand about 1.35v ?
        • 21971
        Is the donor board the same revision,what part numbers on both are at PU9301
        • jasko_jacker
          • Oct 2014
          • 1140
          • italy
          It's very strange, both use up1565p not in fixed mode (pin 6 is not to GND) , resistor divider is 10k (pr9312) and 11.8 k (pr9313)
            • 21971
            Originally posted by jasko_jacker
            ok
            The The up1565p is adjustable as well. In the X550VX boardview pin 6 is connected to a resistor divider
            https://pdf1.alldatasheet.com/datash...P1565PQKF.html
            Edit: i was looking at the boardview and datasheet,you posted before me .
            • jasko_jacker
              • Oct 2014
              • 1140
              • italy
              vram voltage = 0.75(1+(11.8/10)) = 0.75(2.18) = 1.635 v
              With these resistors value, the output should be around 1.5V
              but the boardview (version ?) and my reading is 1.35 v , on the asus site I see a model upgrade (x550vxk).
              probably there is something that I do not understand but since the cards are identical also for revision I change the vram elpida with the samsung
                • 21971
                what are the resistor values on the donor board
                • jasko_jacker
                  • Oct 2014
                  • 1140
                  • italy
                  it's the same 10k and 12k with these values and using the formula on datasheet the result should be around 1.5v and not 1.35
