lenovo yoga 13 2191 no turning on
  • questore
    • Dec 2015
    • 500
    • csongrád
    Hi guys.
    Laptop is not reacting to power button at all, no lights, no blinks no beeps or anything. Removed every component and the battery too.
    DCIN 20v is present until the first mosfet, but not at its gate.
    (SUSPECTING the BQ735 charger chip bacuse it worked from battery while it had some power.)
    So made some voltage readings on BQ735 below:
    1 ACN - 0.906 v
    2 ACP - 0.906 v
    3 CMSRC - 0v
    4 ACDRV - 0v
    5 ACOK- 0v
    6 ACDET - 2,75 v
    7 IOUT - 0v
    8 SDA- 0v
    9 SCL - 0v
    10 ILIM - 0v
    11 BATDRV - 2,12 v
    12 SRN - 1,07 v
    13 SRP - 1,07 v
    14 - GND
    15 LODRV - 0
    16 REGN - 6,08 v
    17 BSTR - 5,9 v
    18 HIDRV - 1,07 v
    19 PHASE - 1,07 v
    20 VCC - 20 v
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: lenovo yoga 13 2191 no turning on
    Yes, Replace the charger IC.
    • Sametbey
      • Jan 2021
      • 229
      • Turkey
      Since it works with a battery, there is no short circuit in the + B19V line. Are your entrance mosfets intact? There are voltage values in the diagram, check it. your charging chip may be defective.
      I'm not happy to be so strong. because it's not humanly
      • questore
        • Dec 2015
        • 500
        • csongrád
        Replaced BQ735 but no change. Every value is the same.
        • mon2
          • Dec 2019
          • 14216
          Is the +3v3 rail working on this logic board?
          It is required for the pull-ups on the i2c lines; ilim and other pins.
          Ilim is built from.a resistor based voltage divider and cannot be 0 volts (unless the pull up resistor or +3v3 are missing).
          Please confirm.
          • questore
            • Dec 2015
            • 500
            • csongrád
            Reworked the new bq chip since one of the soldering was loose and not connected:
            Had a fanspin for 5 sec when connected the charger but now its nothing.
            Laptop still does not turn on when pressing the power button.
            New values of BQ735:
            1 ACN - 20v
            2 ACP - 20v
            3 CMSRC - 19,5v
            4 ACDRV - 25,1v
            5 ACOK- 0v
            6 ACDET - 2,75 v
            7 IOUT - 0v
            8 SDA - 0v
            9 SCL - 0v
            10 ILIM - 0v
            11 BATDRV - 2,75v
            12 SRN - 2,73v
            13 SRP - 2,73v
            14 - GND
            15 LODRV - 0v
            16 REGN - 6,08 v
            17 BSTR - 5,9 v
            18 HIDRV - 2,73v
            19 PHASE - 2,74v
            20 VCC - 18,3v ans sometimes goes down to 16v
              • 20938
              whats the motherboard part number, is there a schematic
              • questore
                • Dec 2015
                • 500
                • csongrád
                I have no schematic
                MB numbers:
                38200164
                9002035
                Yoga 13 MB panasonic
                • questore
                  • Dec 2015
                  • 500
                  • csongrád
                  Please confirm.
                  Pull up resistors are present and not blown.
                  I have not found 3.3v or 5v anywhere but i have no schematic
                  Also 20 VCC - 18,3v and sometimes goes down to 16v and it is abnormal
                  • mon2
                    • Dec 2019
                    • 14216
                    https://www.elvikom.pl/lenovo-yoga-1...ad-t53251.html
                    Monitor my post from a few minutes ago:
                    https://e2e.ti.com/support/power-man...is-the-bq24735
                    So this is interesting:
                    (from)
                    https://e2e.ti.com/support/power-man.../956290/bq735f
                    see markings information - attached.
                    Respectively, full datasheets for the BQ24735 are posted on the TI website.
                    • mon2
                      • Dec 2019
                      • 14216
                      If the 20V DCIN is dropping down then some excessive load is causing the event.
                      Remove the front side mosfets, starting with the one closest to the DCIN connector and continue to check if the DCIN voltage drops down or remains stable.
                      Power down and check for any shorted caps - check the resistance to ground on this main rail and also at every coil to ground. Any super low resistance values (ohms) ?
                      • questore
                        • Dec 2015
                        • 500
                        • csongrád
                        DCIN mostfets are both 20v on source and drain too so they are fine.
                        • questore
                          • Dec 2015
                          • 500
                          • csongrád
                          Of course only when i plug in the battery then I got voltages on drain.
                          BQ735 pin #20 VCC resistance is sometimes 0 Ohm sometimes not . I can try to remove the resistor and the capacitor right on that line to see if 0 ohm remains
                          • mon2
                            • Dec 2019
                            • 14216
                            BQ735 are the markings of the BQ24735 charger IC.
                            Please see attached.
                            • questore
                              • Dec 2015
                              • 500
                              • csongrád
                              A Voltage Regulator IC numbered 8150L (QFN 16) got shorted.
                              Found with an infrared camera.
                              I ordered a replacement (30 days shipping at best) Be back with result after replaced the IC.
                              • questore
                                • Dec 2015
                                • 500
                                • csongrád
                                Realized there is more problem with the board.
                                After removed the 8150L IC, the short to ground around it has gone BUT...
                                The BQ735 charger chip still has low VCC.
                                I have a 2Ohm short on 3.3v I think,because:
                                SDA, SLC, ACOK, and ILIM pin goes to 3.3v with a resistor and all further end of those resistors are 2 Ohm to ground.
                                I'm i correct?
                                Whats next?
                                • DanielDacko
                                  • Mar 2015
                                  • 325
                                  • Macedonia
                                  I'm i correct?
                                  Whats next?
                                  Inject 1V unlimited A and see what heats up.
                                  I don't provide help for people using CH341A and a clip.
                                  • questore
                                    • Dec 2015
                                    • 500
                                    • csongrád
                                    I have ordered parts for lab power supply and see whats happens after injecting 1v
                                    • questore
                                      • Dec 2015
                                      • 500
                                      • csongrád
                                      In the meantime i have measured the resistor value in VCC line right next to bq735 and it is 37kOhm so I think it needs to be replaced. Since I don't know what was the original value I will replace it with the most common 10 Ohm resistor.
                                      • mon2
                                        • Dec 2019
                                        • 14216
                                        37k on Vcc is too high. Yes 10 ohm sounds correct. Also inspect the dual diode on your logic board if present that feeds this rail.
                                          Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-07-2024, 05:00 AM
                                          Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 6 boardview and X1 Yoga Gen 6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
