Problem with asus x541
  • Titoo73
    • Nov 2020
    • 99
    • buenos aires
    Good people, how are you? They can give me a hand. I got an Asus X541 that does not turn on. I started checking and the entry mosfet was short. It was replaced, but the 19v did not pass to the other side. Looking a bit at the Boardview, I realized that I have no voltage in ACOK (0.5v) according to the datasheet it has to be high, I have 18.55v in VCC and 2.4v in ACDET. Any way to go? Thanks!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Problem with asus x541
    Try replacing the charging IC.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3575
      • slovakia
      ACDET must be above 2.4V. mostly 2.7V. so check resistor divider
      • DarkMooon
        • Apr 2021
        • 11
        • UA
        2.4v in ACDET
        2,5-2,7v
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3575
          • slovakia
          Originally posted by DarkMooon
          2,5-2,7v
          no. 2.5-2.9V. 2.7 is normal
          • Titoo73
            • Nov 2020
            • 99
            • buenos aires
            replace the ic, ACDET is 2.5v. I had to change one of the resistors. Will it have a difference from 2.5v to 2.7v?
            • Titoo73
              • Nov 2020
              • 99
              • buenos aires
              in the boardview it appears that it has a divisor of 127k 1% and 20k 1%
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                acdet AT 2.5v is not a problem as its very close to the desired value. In my experience it works at 2.5-2.7v range without much issues. Try replacing the charging IC first as your acok at 0.5V is the real issue.
                • Titoo73
                  • Nov 2020
                  • 99
                  • buenos aires
                  I already replaced it twice. The truth is that I find it strange
                  • Titoo73
                    • Nov 2020
                    • 99
                    • buenos aires
                    raise the resistor that joins acok with the rest of the board and now I have 1.2v, on the other side I have a mosfet (pq8905) I'm going to leave the boardview in case someone can give it a look
                    • Titoo73
                      • Nov 2020
                      • 99
                      • buenos aires
                      Boardview
                      • Titoo73
                        • Nov 2020
                        • 99
                        • buenos aires
                        ok, I put it back together because I remembered the Asus screw and it turned on. The point is that the joy lasted 15sec. I am suspecting a Schottsky diode that is linked to the load IC
                        • Titoo73
                          • Nov 2020
                          • 99
                          • buenos aires
                          I think the motherboard is cursed. It had started after changing the diode in a stable way. The battery is bad, it was replaced, but now I have no image
                          • AtelierRepa
                            ASUS X712JA problem
                            by AtelierRepa
                            I have a problem with the bios, let me explain.
                            With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                            I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                            My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                            The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                            06-15-2024, 04:33 AM
                          • Dobrowol
                            Asus GA402RK keyboard and kb backlight problem
                            by Dobrowol
                            Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                            04-28-2025, 04:30 PM
                            ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                            This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                            09-07-2024, 02:50 AM
                            ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                            This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                            ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                            This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
