A1990 820-01041-A no video
  • pascable
    • Feb 2018
    • 41
    • France
    Hello everyone
    First of all, thank you for your kindness, I do not speak English and I am using Google Translate to write my message to you.
    Hope you will understand me and can help me.
    Logic board 820-01041-A MacBook A1990.
    It starts up without problem, boots very well on an external screen but no video display on the MacBook screen, no backlighting.
    I am not a great specialist in electronics but I noticed that at pins 43 (0V), 44 (0V), 45 (0V) and 46 (5.5V), of the J8500.
    Is this normal because of another line?
    If you can guide me what to check, thank you very much.
    Sincerely, Pascal (France - Reims)
  • mon2
    • Dec 2019
    • 14662
    Re: A1990 820-01041-A no video
    hello.
    What is the history of this computer? Any liquid damage ? Look for red dots on the logic board which indicate that liquid was spilled.
    No display even if you use a flashlight on the front of the screen ? Can you see the apple logo with the flashlight?
    • pascable
      • Feb 2018
      • 41
      • France
      No trace but liquid received.
      Pa sde backlight, I watched with a lamp.
      • pascable
        • Feb 2018
        • 41
        • France
        Could the fault come from a line other than:
        PP3V3_S0SW_LCD (44)
        PP5V_S0_ALSCAM_F (46)
        PP5V_S0SW_LCD (45)
        These are the pin numbers of the J8500.
        • mon2
          • Dec 2019
          • 14662
          check the attached and post your values.
          added another check point - check the rail BEFORE the current sense resistor.
          where was the liquid damage ? has it been repaired?
          • pascable
            • Feb 2018
            • 41
            • France
            For 1 on C8509 (U8500) = 0V
            For 2 on C8510 (U8501) = 3.3V
            For 3 on R8520 pin 2 = 0V
            For 3 on U8510 1 = 3.38V
            For 4 on U8501 2 = 3.38V
            • mon2
              • Dec 2019
              • 14662
              Please confirm that your results are:
              For 4 on U8510 1 = 3.38V
              For 5 on U8501 2 = 3.38V ; is this the reading on pin 5 of U8501 ?
              • pascable
                • Feb 2018
                • 41
                • France
                I watch this in the morning and first of all, thanks for your help.
                See you later.
                • pascable
                  • Feb 2018
                  • 41
                  • France
                  On my board there is an error. Pin 5 is denoted 6. It goes to pin 1 of the R8520 and it has 0V.
                  C8509 = 0V (no short circuit to GND)
                  C8510 = 3.38V + 3.38V on the 3 and 1 of the U8501
                  R8520 (without component, just solder point):
                  On the 1 = 0V
                  On the 2 = 0V
                  On the 3 = 0.2V not stable
                  On the 4 = 0.1V not stable
                  U8510 on pin 1 = 3.38V
                  U8501 on pin 5 (noted 6 on the boardview) = 0V
                  • sherifbekhit
                    • Feb 2017
                    • 19
                    • alex
                    Hi friends
                    I cant found spi flsh chip
                    Any body can help me plz.
                    • pascable
                      • Feb 2018
                      • 41
                      • France
                      What is "flsh spi chip"?
                      Apple reference please and I will help you.
                      • wws911
                        • Apr 2020
                        • 10
                        • South Africa
                        Hey have same kind of issues. Apparently liquid damage.. we're do I check
                        • alfredodinolfo
                          MacBook Pro 2019 (A1990)
                          by alfredodinolfo
                          mb code:820-01827-A;
                          sn:C02Z349ALVDR;
                          i9 32GB Ram 1TB
                          Hi, I found short on one of 6 black nand (total 1TB).
                          i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                          I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                          macbook with A2141 configuration run on recovery but don't complete it.​
                          anyone can help me?
                          05-26-2025, 09:27 AM
                        • robka
                          MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                          by robka
                          my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                          I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                          The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                          After that the Macbook was dead. It isn't charging anymore.
                          The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                          03-02-2024, 02:58 PM
                        • sdogs
                          macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                          by sdogs
                          Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                          First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                          I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                          06-27-2025, 01:58 PM
                        • sdogs
                          by sdogs
                          06-27-2025, 11:26 AM
                        • DATATECH85
                          Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                          by DATATECH85
                          I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                          The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                          I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                          However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                          Here are the values...
                          07-24-2024, 06:34 AM
