Dell Latitude E5540 power On than Off after 5 seconds.
  • lapfix
    • Mar 2020
    • 2733
    • my workshop
    Hello my friend.
    Dell Latitude E5540 LA-A101P power On than Off after 5 seconds.
    At first i find a burned Capacitor PC437 ,after desoldered try to power on , laptop is on , fan spinning , 0.440 amp taken ; 5 seconds and he is
    Off.
    With diode mode try to find any short at all coils , but all is OK.
    In this 5 seconds try to take the voltages :
    Pl 400 = 19V
    PL 401 = 13.65v
    Pl 52 = 3.3v
    PL 53 = 5.21v
    PL 51 =13.65v
    PL 100 = +1.35V_MEN_P
    PL 150 = +1.05V_MP
    PL 300 =+VCC_CORE = 1.7V
    PL 200 = +1.5V_RUNP
    Bios PIN 8 = 3.33v
    PQ 400 = D=19v...G=0v !...S= 19v
    The gate here must be Low !
    U46 = +3.3V_RUN/+5V_RUN present
    U43 = +3.3V_ALW_PCH/+1.05V_RUN present
    U45 = +3.3V_SUS/+3.3V_M present
    UC3 = PCH_PLTRST#_EC = 3.3vTry to flash bios (3 chip ) same issue too !
    What would i check too !!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell Latitude E5540 power On than Off after 5 seconds.
    Most likely PU701 is damaged. PQ400 pin4 is not connected to the charging IC here. Its Controlled by PU701. So probe PU701 voltages. This is dell latitude baby!!!
    • lapfix
      • Mar 2020
      • 2733
      • my workshop
      Thank you my friend.
      Yes this is latitude hhhh
      Ok , so if i m understand you , PQ400 Gate must be more than 0V !
      PU 700 :
      Pin 1 = DC_IN = 19V
      Pin 7 = DC_BLK_GC = 0V
      Pin 9 = P33ALW2 = 3.21v
      Pin 15 = PWR_SRC =19v
      Pin 18 = P33ALW = 3.3v
      Pin 22 = DK_AC_OFF_EN = 3.3v
      Pin 24 = ACAV_IN_NB =3.01v
      Pin 27 = P50ALW = 5V
      Pin 33 = DC_IN_SS = 19v
      • Danyo
        • Mar 2021
        PU 700 :
        Pin 1 = DC_IN = 19V
        Hi, there.
        I've got exactly the same problem with Dell Latitude E5540. All measurements are spot on. Have you found a solution.
        • dohcom
          • Feb 2013
          • Ireland
          Hi, i have a similar problem with a Dell Latitude E5570, The 19.5V power rail is dropping to 13.65V not far after the input and that is being maintained around the board, but i am also getting the 5V and 3.3V.
          I dont think the 13.65V is correct, I will be getting the schematic soon so will have further info, and would like any feedback if possible.
          • Udemzy
            • May 2017
            • 161
            • Guatemala
            A simple thing like cleaning dried cooling paste and applying a new one can solve this kind of issues on dell.
            I notice dell is a very sensitive laptop, I've solve a lot of cases like this by just applying thermal paste and sometimes reprogram the BIOS.
            • Stewd
              • Nov 2021
              Hi, did you find out the problem? Same here, 13v on the main power rail but all other voltages are fine. Thanks.
              • piernov
                • Jan 2016
                • 4435
                • France
                https://www.badcaps.net/forum/showthread.php?t=90356
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  13V on main rail is absolutely fine here.Your problem may be elsewhere. read the thread linked by @piernov to know what is narrow voltage charging technology.
