cfeon qh64-104hip replacement chip?
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi I have a issue of this Ic I can red the ID but I cant read the file inside it, I tried everything but no luck maybe the bios chip is problematic,
    I have bios chip with
    WINDBOND ONLY
    25Q64FWSIG
    25Q128FVSSIG
    S5Q64FVSIG
    Can I use listed chip?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: cfeon qh64-104hip replacement chip?
    The chip in the pic is 3V, 8mb flash drive. The listed chip in your stock S5Q64FVSIG may work. The other with word "FW" is 1.8V-so wont work. Another one with :"128" is 16mb chip. However, whether the replacement chip will work or not will depend on the supported chip list in the bios.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3607
      • slovakia
      supported chip list in the bios?
      so bios must read itself to know if it can read from itself?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Have you not heard of VSCC table in bios??
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • ebugs
          Asus laptop EC/SIO chip replacement
          by ebugs
          Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
          I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
          I found the EC chip...
          09-14-2024, 02:09 AM
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
