MacBook Pro 16” A2141 Battery issue
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Dead unit that needed to be revived with T2 Recovery. Computer finally turns on, this is a brand new MacBook Pro. I reinstalled os, works, but one issue. Battery says Service Battery. The battery has one battery cycle. (So it's new and the macbook is new). It wasn't booting before until the reset from T2 DFU mode. Now it boots but the battery is not charging and yes there is no physical water damage. This is a very common issue we are seeing in these models. Any suggestions would help, before we replace the battery.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Re: MacBook Pro 16” A2141 Battery issue
    No suggestions?
    sigpic
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Hey following up!
      Replaced the NEW oem battery (the one apple put in this new macbook and it was dead) replaced it with a new OEM battery and it works now and charges. So battery was an issue.
      sigpic
      • Adamro
        • Sep 2022
        I am a teacher and I have a cart of 25 A2141 Macbook Pros 16". So far 14 of them have needed battery replacement. They sat for over a year due to the lockdown, and 5 were dead when we came back, four more died this spring (plugged in), and despite being plugged in on an intermittent timer, we lost 5 more over the summer... Seems normal, right?
        • mon2
          • 14681
          OMG.
          1) Contact Apple and raise your voice on this issue. Mention that you have boatloads of their product and that you are a decision maker - they do support volume clients such as yourself - regardless of warranty status. Have seen it over and over. Speak nicely but firmly and ask to be escalated to the next level if the first one is not able to assist you.
          Have many local cases including how my buddy with butter fingers dropped his rather new iPAD and cracked the display -> with a sweet sob story -> the management handed over a brand new unit. He was going into attack mode which would have led to having his tires slashed by the Apple store staff. He failed to understand - his kid dropped the unit but Apple has to replace it???
          2) Batteries do have lifecycles and Apple, for the most part, should last around 500-1000 charge cycles. There is a counter inside their BMS (battery management system). Are you confident that the battery is the fault ?
          What are the exact symptoms ? The unit will not charge or hold the charge ? After you replace with a fresh battery, the unit works on battery ok ?
          What does the Apple battery report say? Replace the battery ?
          I am sure that you are not alone on this case, do contact Apple FIRST for assistance and continue to update this thread.
          • mkdj
            by mkdj
            Mark and model: ASUS X571
            Tests already made:
            - I have removed...
            07-14-2025, 09:16 AM
          • Stephen
            MacBook Pro 16" A2141 Battery Issue
            by Stephen
            So I have replaced the battery. First I ordered a battery from Mobile Sentrix on our business account. Come to find out their batteries are not OEM, and after testing it had a charge but the battery would not charge when plugged into the oem 96w charger. So we assumed the battery was defective and asked them send a replacement, which they did, so they sent another one, tested that and nope same issue, battery doesn't charge. It just shows the charger plugged in and the battery status as NOT CHARGING, with 0 cycles.
            So we returned that assuming well its not OEM so nevermind, so I decided...
            10-22-2021, 02:15 PM
          • drlarsen
            MacBook Air M1 A2337 battery/charging issue
            by drlarsen
            Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
            I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
            On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
            After some hours, the battery status did not improve. Restore via DFU did not help.
            I connected the power adapter to a Kill-a-Watt...
            07-17-2025, 02:35 PM
          • Schluchti45
            MacBook Pro A2141 replaced battery not booting from battery not charging. Works with power suppy
            by Schluchti45
            i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
            Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead.
            11-18-2024, 02:05 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
