820-01041 right fan full blow
  • iMuhtaseb
    • Jan 2017
    • 122
    • Palesine
    Liquid was spilled on this A1990 15" 2018 MacBook Pro and it faced power on issues;
    C8153, C8152, U8250 and C8250 all had liquid and corrosion all over them..
    I replaced C8153, C8152 and C8250 successfully.. I pulled U8250 out and gave it a proper cleanup and returned onto the board. (don't have this chip at hand)
    The computer thankfully turned on successfully but it suffered from full fan RPM on both fans randomly.. I looked deeper into it and found that the fan connectors on the keyboard are HEAVILY corroded so I ordered a keyboard for it and I just installed yesterday.. when I turned on the computer for checkup the right fan is stuck at full speed while the left is now normal..
    I used Macs Fan Control to see if I can control that fan but it failed and for some reason it should the fan running at 0 RPM while it's being at its fullest..
    I used a A1707 right fan to test but it was the same..
    PP3V3_G3H_T is present at 3.3v
    PP3V3_G3SSW_SNS is present at 3.3v
    SENSOR_PWR_EN is present at 1.8v
    I'm stuck now.. help?
  • iMuhtaseb
    • Jan 2017
    • 122
    • Palesine
    Re: 820-01041 right fan full blow
    Update: noticed that CA355 was not connecting to ground (it was moved) I reseated it but still same issue..
    What's weird is that right fan keeps blowing even if the computer is asleep or shutdown.
    • ACS-Repair
      • Feb 2021
      • 204
      That is strange... The fans get power from the PP5v0_S5 rail, which should be off if the computer has not started up. Check to make sure that someone hasn't wired it to the wrong bus. Also check the power rails to make sure they are up in the correct order.
      • valente222
        HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
        by valente222
        I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
        there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
        n, please identify.
        330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
        SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
        I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
        06-27-2024, 06:11 PM
      • air_chair256
        Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
        by air_chair256
        I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
        Tried to reball RAM 1,2,3,4
        Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
        02-13-2024, 06:00 AM
      • javieromex
        Dell G15 5511 LA-K452P won't turn on
        by javieromex
        Hello, any help will be apprecited!
        • Model: Dell G15 5511
        • MB: LA-K452P
        • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
        • Customer reported it was turned off and left plugged in during the night and thats it...
        • No signs of liquid damage or burned components.
        Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
        I have checked so far:
        04-17-2025, 12:44 PM
      • Prott
        Surface Pro 7 - SLP_S4 present, then gone
        by Prott
        Hello fellow Badcappers,
        I have a problem with stubborn Surface Pro 7. I narowed it down to disappearing SLP_S4# (gone after around 200 ms).
        Everything else works as it should (the whole power on sequence succesfully finishes, all the voltages are present) until this signal goes missing - with it missing the AND gate causes ALL_SYS_PWRGD to go back low and this makes VCCIN drop to 0 V as well. Interestingly the SLP_S4_DRV# signal from SAM is still present for a second, even after SLP_S4 is no longer there. I wonder what could either cause PCH to stop sending the signal or what...
        12-03-2023, 06:11 PM
      • lapfix
        Lenovo IdeaPad 3 NM-C961.no display
        by lapfix
        Hello everyone.
        lap and motherboard : IdeaPad 3-15IGL05 Laptop - Type 81WQ
        NM-C961.
        Behaviour : connect charger it power on automatically ,reach 0.170 amp than down to 0.74 amp...no display.
        with battery connected it reach 980 amp than 870 ...no display
        No short ; no corrision no intervention before.
        Try 2 differents bios versions same behaviour.
        Some measuremets :
        PL 1600 = 5valw present
        pl 1100 = 3 vlalw present
        pl 100 = 0.221 v without battery and when battery connected 7.8 volt
        pl 6602 = 1.2 v
        pl 6603 = 1.056v...
        05-29-2025, 05:01 AM
