Toshiba Satellite - Locks up when plugged in
  • tomodachi
    • Apr 2012
    • 613
    • Turkey
    #581
    Re: Toshiba Satellite - Locks up when plugged in
    Very strange case,
    Here is the update, I measure 19V on top pad and 3.3V on bottom .
    I need schematic to shee what is going on,
    [/IMG]
    • rievax_60
      • May 2012
      • 897
      • australia
      #582
      Originally posted by murphyai
      it wasn't possible to rip the capacitor off the board and to be honest you will damage a board in most cases doing that.
      so i melted it off the board with a soldering gun and then the aluminium plate underneath as well.
      i think i haven't soldered the capacitors on correctly.
      i will desolder them later and only add 2 x 470uf 2.5 to the board as that is 940
      i also received a how to guide from the people who supplied me with the capacitors which i will post now for other users here.
      i will let you know later on how the soldering went.
      i only have a multimeter as well
      Have you done the test I mentioned earlier?
      If the NEC/TOKIN capacitor is wired the way I suspect it might be, the laptop will not work.
      • murphyai
        murphyai
        • Nov 2013
        • 26
        • ireland
        #583
        i proceeded yesterday to install 2x 470uf as a replacement for the oe907 chip.
        now the battery is charging where it wasn't before
        however, when i put the laptop fully back together the screen still isn't showing.
        i used thermal grease instead of thermal pads on the gpu.
        would this be the cause or something else?
        power lights come on and fan and battery charger are showing as working as well.
        • dj_ricoh
          • 2073
          • uk
          #584
          i don`t understand why you all use 2x470 you need to pass 1000 and reach atleast 1200
          • murphyai
            murphyai
            • Nov 2013
            • 26
            • ireland
            #585
            did not know i had to pass 1000
            i'll add another 470uf to the board later on and see how that goes
            • murphyai
              murphyai
              • Nov 2013
              • 26
              • ireland
              #586
              does it not have to be 2 capacitors each side?
              • murphyai
                murphyai
                • Nov 2013
                • 26
                • ireland
                #587
                • murphyai
                  murphyai
                  • Nov 2013
                  • 26
                  • ireland
                  #588
                  • dj_ricoh
                    • 2073
                    • uk
                    #589
                    2x330uF one side and 2x330uF other side
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      #590
                      Originally posted by spleenharvester
                      Good luck man! Always a satisfying feeling when it boots and runs properly straight away
                      Just remember to check your polarities and check for continuity between the two sides before you fire it up!
                      Can you say more about checking between the two sides? I have been suspecting that the tracks under the outer + strips may not be connected on some mainboards. I have not been able to confirm this.
                      • murphyai
                        murphyai
                        • Nov 2013
                        • 26
                        • ireland
                        #591
                        i added the third capacitor but no improvement.
                        i'll test the outer + strips with a multimeter later.
                        what reading should i get though usually?
                        if there is no reading, do i connect the 2 + strips by any old wire?
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          #592
                          If the reading is open then the strips need to be connected fairly well. Tens of amps flow into the CPU.
                          I dont know exactly what would be enough. I think I would start with 2 resistor lead off cuts, then if the laptop is working, I would measure the voltage drop and have a think about it.
                          • rievax_60
                            • May 2012
                            • 897
                            • australia
                            #593
                            This photo is from another thread here. Notice that the track area for the bottom most + strip has very few vias in it, not nearly enough to carry the CPU current to the other side.
                            • murphyai
                              murphyai
                              • Nov 2013
                              • 26
                              • ireland
                              #594
                              that looks different to the pcb board on the acer 6920g when the oe907 chip has been removed.
                              when you say vias what do you mean?
                              • murphyai
                                murphyai
                                • Nov 2013
                                • 26
                                • ireland
                                #595
                                i've a funny feeling that i should have soldered a trail between the - connectors as there was a aluminium plate under the nec tokin chip that connected the 2.
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  #596
                                  Vias are copper lined holes that form connections between tracks on the various PCB layers.
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    #597
                                    I would expect that the - strips are connected by copper print.
                                    • dougsanti
                                      • Dec 2013
                                      • Costa Rica
                                      #598
                                      I am new to the forum and I appreciate a lot all of the information regarding this issue with these caps.
                                      I found these 220uF caps: TAJB227K004RNJ. Being pack B, it seems to me that 6 of these buggers would fit nicely there. Length 3.5 mm.
                                      Can somebody confirm if this is a good fit and comment on it? Thank you.
                                      • rievax_60
                                        • May 2012
                                        • 897
                                        • australia
                                        #599
                                        The ESR is too high. http://www.datasheets360.com/pdf/332...2303?comp=4002
                                        • donshinoda
                                          • Dec 2013
                                          • philippines
                                          #600
                                          thanks for the infos, I have the same auto shutdownd problem when i plug in power adapter ,I have Toshiba satelite L300
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:10 PM
