Toshiba Satellite - Locks up when plugged in
  • Napalm
    • Mar 2013
    • 20
    • Portugal
    #481
    Re: Toshiba Satellite - Locks up when plugged in
    Success.
    I ordered 4 330uf from here: http://www.mobofix.info/loja/product.php?id_product=262
    It was a little hard to solder this, but now the board posts.
    Then I tried booting to windows and worked fine from the charger only, but then started making a buzzing noise.
    Is it normal?
    • rievax_60
      • May 2012
      • 897
      • australia
      #482
      Originally posted by Napalm
      Success.
      Is it normal?
      Well done.
      I hear a low level buzzing from some of these laptops also. I found it to be coming from the Vcore regulator area when the Vcore voltage starts rapidly shifting between two levels for power saving.
      • madhava
        • Mar 2013
        • usa
        #483
        Hi
        I've got 2 satellite laptops (M205 and an A305) with the same problem of restarting while plugged into AC power (& running no problem on battery). With M205 sometimes also the display becomes just all colored/horizontal lines. I'm hoping that replacing the caps will fix both laps.
        I'm seeing several variations here on which caps to use. I'm looking at ordering these ones here: 330UF 2.5V D 7343-31 SMD Tantalum capacitor SMT337
        Can someone tell me if these should do the job for both laps ? I'm looking at getting 2 sets of these and using 4 on each laptop.
        And some description of the soldering process would be helpful. Do you just put a couple drops of solder on the board and then put the cap in place ?
        • rievax_60
          • May 2012
          • 897
          • australia
          #484
          I cant find their part number. The D 7343-31, is just the number for the case size. Maybe someone else can spot the part number.
          • rievax_60
            • May 2012
            • 897
            • australia
            #485
            There is a lot to explaining how to solder. Its best to search the internet about "SMD soldering".
            • Sindong
              • Mar 2013
              • Philippines
              #486
              This solution works but instead of using 4 330 caps i used 6 220's.
              L300 working like new now. . .
              • teknub
                • Dec 2012
                • 6
                • Philippines
                #487
                Can this work on Toshiba Satellite L300 1A3 System Unit with NEC problems.
                Link below:
                http://philippines.rs-online.com/web...itors/7372838/
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  #488
                  Link below:
                  Four of those should work although the ESR should be a bit lower.
                  Most others use four 330uf capacitors. There could be an ESR advantage in using more of a lower value capacitor, like six 220uf.
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    #489
                    The best choice would be four NTP337M2.5TRV(9)F. The (9) in the part number indicates the ESR. Lower is better.
                    Edit- I just noticed they dont stock the NTP337M2.5TRV(9)F. The NTP337M2.5TRV(12)F will have to do.
                    • teknub
                      • Dec 2012
                      • 6
                      • Philippines
                      #490
                      Thanks reivax_60 I'll try to acquire that.
                      • bpsorin
                        • Mar 2013
                        • romania
                        #491
                        hi, I have L350 toshiba satellite i replace NEC/TOKIN 0E128 with 4pcs 330uf 2.5v (panasonic EEFSX0E331ER) caps and it works, thank you,
                        • fddizon
                          • Sep 2011
                          • 555
                          • Philippines
                          #492
                          Never seen one of those capacitors. where did you get them?
                          • bcohen
                            • Apr 2013
                            • US
                            #493
                            I have just replaced the motherboard in my Toshiba Satellite L305, and would like to know if there is any way to prevent this capacitor from going bad again. Would it help to only plug the AC adapter in while the computer is powered off?
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              #494
                              To me it looks like the capacitors are mounted on their sides.
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                #495
                                The only useful way I can think of is to keep the CPU temperature under control.
                                Not always easy to do when things like Internet explorer cause high CPU usage for no good reason.
                                Many faulty A200 laptops I see have blocked heatsink fins.
                                I like to set the fan control to Performance mode.
                                There may be other factors than can not be easily controlled such as high humidity. The nec/token capacitor is not sealed well.
                                • bpsorin
                                  • Mar 2013
                                  • romania
                                  #496
                                  https://cdn.badcaps-static.com/pdfs/...447681cf7d.pdf
                                  http://www.adelaida.ro/c-330uf-2.5v-...panasonic.html
                                  • juan23
                                    • Apr 2013
                                    • canada
                                    #497
                                    Which one is the better choice for A205
                                    T520V337M2R5ATE007 2.5 v or
                                    T520V337M004ATE007 4 v ?
                                    And how many should I get 4 pcs or 6 pcs ?
                                    thanks in advance for any input
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      #498
                                      I have not used tantalum capacitors for myself. Others have no problems with 4 x 330uf.
                                      Although 2.5v is perfectly adequate, there is no problem with a higher voltage rating. The 4v version is cheaper at Mouser.
                                      • fddizon
                                        • Sep 2011
                                        • 555
                                        • Philippines
                                        #499
                                        hehehe... i took a good look and indeed mounted on their sides...lol
                                        thanks
                                        • crpnop
                                          • Mar 2013
                                          • spain
                                          #500
                                          Thanks all for the helpfull thread. I've successfully repaired a L305 with the instructions here provided.
                                          Kudos.
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-11J boardview and Satellite Pro R50-EC-11J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 08:10 PM
