LA-7551P 3V and 5V not present
  • yulianbuds
    • May 2019
    • Indonesia
    Hello everyone. I have problem in motherboard with code board LA-7551P
    My problem is 3V and 5V is not present. This is my result after measure the output on the IC RT8205LZQW
    - ENTRIP1 = 1.7V
    - ENTRIP2 = 1.3V
    - SKIPSEL, TONSEL, VREF = 2V
    - EN = 3.0V
    - BOOT1, BOOT2 = 4.5V
    - VREG3 = 3.4V
    - VREG5 = 5.0V
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: LA-7551P 3V and 5V not present
    Pin23-PowerGood is present??? FB1/FB2 Voltage??
    • piernov
      • Jan 2016
      • 4435
      • France
      Did you check for short to ground?
      • valente222
        HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
        by valente222
        I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
        there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
        n, please identify.
        330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
        SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
        I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
        06-27-2024, 06:11 PM
      • air_chair256
        Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
        by air_chair256
        I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
        Tried to reball RAM 1,2,3,4
        Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
        02-13-2024, 06:00 AM
      • javieromex
        Dell G15 5511 LA-K452P won't turn on
        by javieromex
        Hello, any help will be apprecited!
        • Model: Dell G15 5511
        • MB: LA-K452P
        • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
        • Customer reported it was turned off and left plugged in during the night and thats it...
        • No signs of liquid damage or burned components.
        Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
        I have checked so far:
        04-17-2025, 12:44 PM
      • Prott
        Surface Pro 7 - SLP_S4 present, then gone
        by Prott
        Hello fellow Badcappers,
        I have a problem with stubborn Surface Pro 7. I narowed it down to disappearing SLP_S4# (gone after around 200 ms).
        Everything else works as it should (the whole power on sequence succesfully finishes, all the voltages are present) until this signal goes missing - with it missing the AND gate causes ALL_SYS_PWRGD to go back low and this makes VCCIN drop to 0 V as well. Interestingly the SLP_S4_DRV# signal from SAM is still present for a second, even after SLP_S4 is no longer there. I wonder what could either cause PCH to stop sending the signal or what...
        12-03-2023, 06:11 PM
      • lapfix
        Lenovo IdeaPad 3 NM-C961.no display
        by lapfix
        Hello everyone.
        lap and motherboard : IdeaPad 3-15IGL05 Laptop - Type 81WQ
        NM-C961.
        Behaviour : connect charger it power on automatically ,reach 0.170 amp than down to 0.74 amp...no display.
        with battery connected it reach 980 amp than 870 ...no display
        No short ; no corrision no intervention before.
        Try 2 differents bios versions same behaviour.
        Some measuremets :
        PL 1600 = 5valw present
        pl 1100 = 3 vlalw present
        pl 100 = 0.221 v without battery and when battery connected 7.8 volt
        pl 6602 = 1.2 v
        pl 6603 = 1.056v...
        05-29-2025, 05:01 AM
