MAcBook Pro A1707 new keyboard not working but touchpad and fans work properly.
  • kalzabdul
    • Sep 2020
    • 28
    • Uganda
    hi. I have an a1707, i replaced with a new keyboard but still no working
    The touchpad works well and the fans spin but keyboard is not working. Any help please.
  • kalzabdul
    • Sep 2020
    • 28
    • Uganda
    Re: MAcBook Pro A1707 new keyboard not working but touchpad and fans work properly.
    • mon2
      • Dec 2019
      • 14677
      hi.
      1) check the keyboard cable to the logic board connection
      2) do you see the keyboard backlight working on this replacement?
      • kalzabdul
        • Sep 2020
        • 28
        • Uganda
        no backlight
        Am yet to get another connector
        But the fans are working well
        • mon2
          • Dec 2019
          • 14677
          On the connector, just visually confirm that there are no bent pins. We have done similar keyboard replacements at the low level and worked well in the end but it was not the same A1707 unit.
          Just confirm that the keyboard cables are mating correctly.
          There are some youtube videos on this topic - please review them as well.
          • kalzabdul
            • Sep 2020
            • 28
            • Uganda
            Ok I'll check on the connector.
            Do you have any links to those videos
            • kalzabdul
              • Sep 2020
              • 28
              • Uganda
              Hi. I’ve tried another connector but it didn’t work.
              So i got another motherboard and fixed it in the chasis woth the faulty keyboard but still it didn’t work.
              Am probably thinking that the new keyboard isn’t just working.
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 674
                It is not uncommon to receive new keyboards and they do not work. If you ordered them from china i would be careful because they resell returns. You will want to buy from a reputable company that sells OEM parts. FYI, the keyboard has the backlight integrated inside the keyboard itself, there is no connector for the backlight on these keyboards, they are all in one connection. I seen cases where the keyboard works but the backlight does not, and vice versa.
                sigpic
                MEOWING IN THE IMPOSSIBLE UNIVERSE!
                • kalzabdul
                  • Sep 2020
                  • 28
                  • Uganda
                  Ok. So let me just buy another keyboard. Coz even the backlight isn’t working on this one.
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 674
                    I would recommend you buy a topcase with a battery (new top case) or even a known used one that is working. There are people selling these on eBay always.
                    sigpic
                    • kalzabdul
                      • Sep 2020
                      • 28
                      • Uganda
                      Ok. Thanks
                      • Herby94
                        MacBook Pro A1707 Won’t Boot – No Display, Fans Spin Briefly
                        by Herby94
                        I’m currently having an issue with my MacBook Pro (A1707). It doesn’t power on or make any sounds.
                        • The charger is a generic third-party unit that had a loose connection at the AC input (127VAC). I fixed it, and now it delivers 20VDC to the laptop.
                        • When connected, the fans spin for about 30 seconds before shutting off.
                        • No display, no audio, and no signs of life during this time.
                        Any ideas? Could this be a logic board issue, or is the charger still a problem? Thanks in advance!...
                        08-07-2025, 08:59 AM
                      • playit
                        ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                        by playit
                        my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                        my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                        few years back ps2 mouse stopped working, but ps2...
                        12-23-2024, 06:05 AM
                      • Vliegenier04
                        Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
                        by Vliegenier04
                        Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
                        I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
                        Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
                        06-16-2025, 12:03 PM
                        HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse boardview and 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                        09-06-2024, 06:21 AM
                        HP ProBook 430 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 430 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + Essential 15.6-inch Case, Keyboard & Mouse boardview and 430 G5 + Essential 15.6-inch Case, Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
