MSI GP72 6QE Leopard Pro
  • Rhadu23
    • Mar 2021
    • 74
    • United Kingdom
    Hello Everyone,
    Here I am again with another request of help form more skilled people.
    Have this MSI GP72 6QE Leopard Pro.
    Motherboard: MS-16J51 ver 1.0
    Power button flashes when pressed for a fraction of a second and nothing happens.
    Measured voltages and all look to be fine. It just wont start.
    Would someone be able to help me with it?
    PS: it does charge the battery
    Already did a BIOS reprogram with one found on the internet (only one that was for free) and still nothing.
    Your help would be highly appreciated.
    Regards
    • 21889
    Re: MSI GP72 6QE Leopard Pro
    Check the random bios you found with MEAnalyzer - https://github.com/platomav/MEAnalyzer/releases ,if the "File System State" says "Initialised" is has dirty ME FW,in other words its already been booted on another machine and the ME FW would need cleaning.
    MSI have full bios versions at the support site, (with "Configured" clean FW), flash the bios and take the repair from there if it still has problems,at least you`ll know the bios is working 100% so you can rule it out - https://www.msi.com/Laptop/support/G...opard-Pro.html
      • 21889
      Post voltage measurements on all large grey coils and post a link to the schematic or post it here if you have it.
      • Rhadu23
        • Mar 2021
        • 74
        • United Kingdom
        have no schematic.
        rebuilding an alienware at the moment.
        will post voltages in a bit
          • 21889
          Schematic - https://www.badcaps.net/forum/showthread.php?t=68522
          • Rhadu23
            • Mar 2021
            • 74
            • United Kingdom
            Here are some voltages....
            • Rhadu23
              • Mar 2021
              • 74
              • United Kingdom
              does the picture helps in any way?
              • rediii
                h???, spurrrn
                • Mar 2018
                • 501
                • somewhere in europe
                nevermind
                • Rhadu23
                  • Mar 2021
                  • 74
                  • United Kingdom
                  Originally posted by rediii
                  nevermind
                  • rediii
                    h???, spurrrn
                    • Mar 2018
                    • 501
                    need more information. what i know is, that the kbc-chip is going bad frequently on these machines...
                    • Rhadu23
                      • Mar 2021
                      • 74
                      • United Kingdom
                      could you please point me to that chip? where is it on the board?
                      • rediii
                        h???, spurrrn
                        • Mar 2018
                        • 501
                        its the 128-pin qfn chip from ene . the big multicontroller with kapton tape on top (yellow tape)
                        • Rhadu23
                          • Mar 2021
                          • 74
                          • United Kingdom
                          so I will need to buy one of those
                          do they need any programming?
                          • rediii
                            h???, spurrrn
                            • Mar 2018
                            • 501
                            gimme chip code, do it has dedicated ec-bios on the other side? try me cleared bios first...
                              • 21889
                              Page 1 of the schematic lists all the major IC`s. KBC KB9028C (page 28).
                              Yes it does need programming.You might be able to buy a pre programmed chip on ebay.If you are going to keep working on laptop repairs then a KBC/IO programmer is a must have tool so that you can program them yourself.
                              I recommend the vertyanov jig, other programmers are SVOD 3 (also programs SPI) ,SAS ioprogrammer (vertyanov clone).
                              https://www.ebay.co.uk/itm/Sergey-Ve...-/113543135478
                              https://www.ebay.co.uk/itm/ITE-ENE-I...e/172747611949
                              https://svod-project.com/en/products...grammer-ver3-3
                              • Rhadu23
                                • Mar 2021
                                • 74
                                • United Kingdom
                                KB9028Q C
                                NF511864
                                GCA150908
                                them 3 lines are written on the chip
                                  • 21889
                                  Don`t assume its the EC thats dead unless youve checked the working voltages. Have you checked PQ4 ,PQ5 mosfets ?
                                  • Rhadu23
                                    • Mar 2021
                                    • 74
                                    • United Kingdom
                                    will check them as soon as I get home
                                    • Rhadu23
                                      • Mar 2021
                                      • 74
                                      • United Kingdom
                                      PQ4 has 19.5v on all pins but pin4. On pin 4 has 8.2v
                                      PQ5 has 19.5v on all pins but pin4. On pin 4 has 9.6v
                                        • 21889
                                        check the voltage on +3VALW,+5VALW,SRTCRST# ,RTCRST# .Does the power button go 3.3V - 0V - 3.3V when you press it
                                          MSI Gaming GP72 7RE Leopard Pro-200 Notebook GP Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GP72 7RE Leopard Pro-200 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GP72 7RE Leopard Pro-200 boardview and GP72 7RE Leopard Pro-200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 07:10 AM
                                          MSI Gaming GP72 7REX-629IT Leopard Pro Notebook GP Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GP72 7REX-629IT Leopard Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GP72 7REX-629IT Leopard Pro boardview and GP72 7REX-629IT Leopard Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:11 AM
                                          MSI Gaming GP72-2QEi581FD (Leopard Pro) Notebook GP Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GP72-2QEi581FD (Leopard Pro) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GP72-2QEi581FD (Leopard Pro) boardview and GP72-2QEi581FD (Leopard Pro) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 05:30 AM
                                          MSI Gaming LEOPARD GP66 11UG-690CA Notebook GP Specification for Upgrade or Repair
                                          This specification for the MSI Gaming LEOPARD GP66 11UG-690CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LEOPARD GP66 11UG-690CA boardview and LEOPARD GP66 11UG-690CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
                                          MSI Gaming GL65 10SFK-640FR Leopard Notebook GL Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GL65 10SFK-640FR Leopard Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL65 10SFK-640FR Leopard boardview and GL65 10SFK-640FR Leopard schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 09:10 PM
