Apple Macbook A1398 Turns off randomly
  • Eleways
    • Oct 2014
    • 62
    • Italy
    I have a problem on a Macbook A1398 with motherboard 820-3787-A.
    It works fine, but sometimes it turns off.
    I noticed that it happens more frequently with the battery plugged, so I changed the battery, but it does the same.
    It also heats up a lot.
    Any suggestions?
    Thank you
  • mon2
    • 14731
    Re: Apple Macbook A1398 Turns off randomly
    Could be a thermal shutdown due to blocked exhaust vents. How dirty is the inside of the machine? Give it a good cleaning. Is the fan moving (if one is present)? The heatsink compound for the CPU could also be dry due to the age of the machine which will require a fresh application.
    • piernov
      • Jan 2016
      • 4439
      • France
      Turns off suddenly or freezes/goes black screen (possibly with fans spinning fast) and turning off a short after after?
      • Eleways
        • Oct 2014
        • 62
        • Italy
        I had thought that, so I cleaned it and changed the heatisink compound, but nothing changed. The fans work fine.
        • Eleways
          • Oct 2014
          • 62
          • Italy
          It turns off suddenly, and sometimes it reboots.
          • rediii
            h???, spurrrn
            • Mar 2018
            • 503
            • somewhere in europe
            i think think it's one of these problems? https://boards.rossmanngroup.com/thr...y-ideas.52234/, https://boards.rossmanngroup.com/thr...ng-down.60637/
            i think you can test this with disabling thunderbolt
            • ACS-Repair
              • Feb 2021
              • 204
              What model year is the MacBook Pro?
              U8900 bad chip connections is a well known issue on the 2012-2013 models. Use solder paste and re-solder the pins with a micro tip soldering iron. This usually brings it back.
              • piernov
                • Jan 2016
                • 4439
                • France
                820-3787 is the L2013 model. Doesn't have U8900 solder joints defect. It's still not impossible to have an issue with U9300 but very unlikely.
