820-01041 cycling
  • iMuhtaseb
    • Jan 2017
    • 125
    • Palesine
    820-01041 cycling
    Hello everybody and I hope you all doing well!
    I have a 820-01041 on me that shows the Apple logo for a second and it shuts off immediately.. I cannot boot into recovery OS even.
    When I turn on and hold the alt key it remains on forever, when its asked to into Macintosh HD it shuts down again.
    T2 revive was attempted and did not help (restore didn't work).
    The computer turns on taking 20V with up to 1.2A for a couple of minutes then drops to 0.02A and again..
    This is a weird one because no prior liquid damage or corrosion anywhere.. the computer is just squeaky clean.
    I'm suspecting a bad T2 chip but I wanted some advice and to be honest I don't know where to start with this one!
    I appreciate every help!
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 820-01041 cycling
    I don't know for this one exactly, but some newer boards with dGPU require a known good battery to boot fully into macOS.
    • high-tech
      Samsung UN55F7050AFXZA ver. TD01 power cycling
      by high-tech
      Hello everybody, I could use some help on this one... It's got me guessing...
      I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
      (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
      (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
      (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
      (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
      9. ground (PWM2) 10. 0.9 volts cycling...
      09-15-2020, 03:39 PM
    • usbdevice
      Acer X223HQ (Version Bbd) on/off-power-cycling
      by usbdevice
      Hi all
      There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
      https://www.badcaps.net/forum/showthread.php?t=50657
      https://www.badcaps.net/forum/showthread.php?t=40512
      The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
      It's my dad's old monitor. He...
      08-05-2022, 02:21 AM
    • huzo
      HP Omen shuts down when loading OS
      by huzo
      The model is 15ec-1061nm
      Board number is DAG3EDMB8D0​
      SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
      10-29-2024, 12:05 AM
    • Giggle2562
      Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
      by Giggle2562
      I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
      The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
      Here's what I've tried so far:
      • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
      • The laptop shows an image on the internal display for a few seconds before it shuts down.
      • I tried swapping the LCD panel with a known good one.
      • I tried swapping the LCD cable
      Yesterday, 12:36 PM
    • riko 656
      Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
      by riko 656
      I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
      Laptop Model:
      • Model: Lenovo Legion Slim 5 16APH8
      • GPU: NVIDIA GeForce RTX 4070
      • Main BIOS chip size: 32MB
      • VBIOS chip size: 16MB
      Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
      What I Have Tried So Far:
      1. I
      11-04-2025, 05:14 AM
