MacBook Pro - A1398 - No Display
  • nrcslim89
    • Nov 2019
    • 129
    • Portugal
    Hello, guys i have here one MacBook Pro A1398 with a logic board 820-3662-03.
    This logic board won't have dGPU so it's an Intel CPU and GPU model.
    I solved one issue with no Green and Orange light with help of piernov, resoldering the U7000 IC.
    But now i have a second problem to try to solve...
    I don't have display as well backlight on internal display.
    So machine power on nice, charges well, all is in function and i have image on external HDMI port.
    But i don't have internal display never... i measure and search for shorts on Backlight area but nothing seems to be in short... i don't have output backlight 55V on PPVOUT_S0_BKLT.
    But theres no short and no bad aspect or look on caps... nothing is getting hot.
    Already replaced the LVDS Connector as well and i know LCD Module is all fine tested on another model.
    By the way i must say that is missing value on PPBUS_S0_LCDBKLT_PWR_SW
    Any help or suggestions ?
    Thanks to all
  • ACS-Repair
    • Feb 2021
    • 204
    Re: MacBook Pro - A1398 - No Display
    Do you know that the display is good and has worked in the past? Is the display original or a replacement? Have you tried connecting an external monitor to see if there is an output?
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Thanks to all
      What year is this in? A1398 depends on the LCD based on years.
      A few things could be wrong here:
      1. Bad LVDS connection on the Logic board. I would start there and test to see if you are getting voltage on any of the pins.
      2. If you are getting voltage, you most likely have a bad LVDS cable on your LCD, Replacing that is fairly simple.
      3. If the cable is not the culprit, the LCD may have a bad CAP. Louis Rossmann shows you how to repair these LCD models if they have a bad cap.
      First and foremost I would try using another LCD of the same year for your MacBook to determine if its an LCD issue or Cable issue. In most cases it is usually a BAD cable that could go out. This happens. If your backlight fuse is not blown then you do not have a short and most likely have a bad LVDS connection if the LCD is good and cable is good. Hope this helps.
      sigpic
      MEOWING IN THE IMPOSSIBLE UNIVERSE!
