Asus A541UV won't detect SSDs. HELP?
  • Tinfomais
    • 20
    • Portugal
    Hi, no matter what I do, I can't get any SSD to be detected, and I've tried 4 diferent SSDs (Micron, Kingston, Kioxia and Transcend), but it detects HDDs the first try.
    Here's what I've tried:
    -Update BIOS from easy flash
    -Reflash BIOS with programmer
    -Reflash EC firmware and flashed back original
    -Cleaned entire motherboard
    -Unplugged everything except SSD and monitor
    -Tried With battery only and Charger only
    -Clear cmos
    -Using optical drive sata
    Ran out of ideas, can anyone help or give me a tip on what I should try next?
    Thanks in advance.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus A541UV won't detect SSDs. HELP?
    tried in legacy mode??
    • Tinfomais
      • 20
      • Portugal
      Yes, forgot to mention that, Tried UEFI and CSM (Legacy mode) and with secure boot on and off.
      • mosfetratus
        Sure Not
        • Feb 2019
        • 174
        • Resistron
        nvme ssds can be detected only with UEFI bios setting. They can be detected with legacy OS booted (W7), but bios will not detect as bootable device.
        Secure boot is only for booting trusted software, from HDD, CD, etc.
        Also what partition GDP or MBR, hdd are formated in? MBR is legacy.
        • Tinfomais
          • 20
          • Portugal
          The laptop came with a Micron 256GB SSD from factory and it suddenly stopped detecting the SSD, it's formated from factory with GPT partition table and windows 10, but the problem shouldn't be the file system nor the partition table because I've worked with other laptops with the same and similar models and it didn't have any problems detecting SSD.
          And just some aditional information, only Sata SSDs, the laptop doesn't have NVMe support.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            are you using the ssd on optical drive bay?? If so,the ssd candy can be the issue.
            • Tinfomais
              • 20
              • Portugal
              Yes and no, I've tried with a known working caddy and in the hdd bay with the same result.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Ok, so the caddy is fine,ssd is known good. You need to measure the voltage on hdd connector.
                • Tinfomais
                  • 20
                  • Portugal
                  3.3V have 3.28v and 5v have 5.04v all within spec.
                  This souldn't be the problem as it detects everything (HDDs and optical drive) except SSDs.
                  Edit: tested the wrong laptop (I have another one with a similar model by its side), 3.3v shows 0v without SSD and 1.78v with SSD and 5v is 5.04v, so the problem is probably between the 3.3v voltage regulator and the sata conector, if not the regulator itself.
                  • Tinfomais
                    • 20
                    • Portugal
                    I've just disassembled the motherboard and upon closer inspection on the daughter board, there are no 3.3v traces, only 5v, and according to the boardview the laptop only has 5v on both sata connectors.
                    • Tinfomais
                      • 20
                      • Portugal
                      Update: Ok, this might be weird, but it started detecting SSDs out of nowhere, and it's booting to windows without any problem.
                      Rebooted many times, and removed battery and it's still detecting the SSD, Asus should learn to make these cheaper laptops more reliable, because from the hundreds of laptops I've fixed until today, I've never seen this happening. Thanks for the help anyway.
                      • piernov
                        • Jan 2016
                        • 4439
                        • France
                        This one seems to have a different connector, but on other Asus laptops the mezzanine connector for the HDD daughter board is a common failure.
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3627
                          • slovakia
