Α1466 (820-00165-A) fanspins!no video, no chime, no corrosion.
  • kosmo
    • Sep 2014
    • 34
    • Greece
    recently they brought me this mac, and it turns on it does the reset and then works with full fan and no chime and no video also no sign of corrosion in the board, any idea?
    • 21907
    Re: Α1466 (820-00165-A) fanspins!no video, no chime, no corrosion.
    Using a genuine charger ? , done a PRAM reset ? .Have you gone through the list of power rails and checked all voltages ?
    • kosmo
      • Sep 2014
      • 34
      • Greece
      yes sir done allready, i also flashed new bios dump but it had the same result so i flashed again the original one.
      • mon2
        • 14667
        We work on a1466 often. Go through the voltage checks.
        Any physical damage to the screen?
        What is the history of this unit as reported by the customer?
        Just stopped working one day? If yes, could be a bad or shorted capacitor but only the voltage checks followed with resistance checks on each rail will assist in troubleshooting this box.
        Post at the very least the major voltage rail values.
          • 21907
          You should mention in the first post what you have tried and what you havn`t we aren`t mind readers .
          • Askic
            • Sep 2018
            • 187
            • BIH
            Okay, first of all, I'm gonna assume that you alread found schematics and boardview for this particular board.
            If I understood OK, if the board is connected to the charger, you have orange light when connected and fan is at full speed, no chime and no video.
            In order to speed up troubleshooting, check whether you have PP3V3_S0 voltage. Inspect area around U8030 load switch. There are probe points very easily accesible, very near to the left of U8030. This switch creates PP3V3_S0 from PP3V3_S5.
            If you don't have 3.3 S0 voltage, you should go back step by step and check which voltages are present, but I assume you don't have S0 voltage and have S3, S4 and S5 voltages. U8030 is on page 58 of schematics. If you have PP3V3_S5, check P3V3S0_EN.
            All power rails are on page 62 of schematics.
            • kosmo
              • Sep 2014
              • 34
              • Greece
              hello there , thanks for all the responses, so when i plug in the charger i have green light and then it goes to orange, i also have a donor a1466 and i checked the lcd panel and i allready checked with different io cable, i also did a quick resistance check to the basic coils and everything is ok no resistance to ground only at cpu coils L7320 L7310 i have 15-20 ohm to ground, i measured all the power rails below :
              PPBUS_G3H 8.56v
              PPBUS_S5_HS_COMPUTING_ISNS 8.55v
              PPBUS_S5_HS_OTHER_ISNS 8.55v
              PPDCIN_G3H_ISOL 14.94v
              PPDCIN_G3H 14.94v
              PP3V42_G3H 3.41v
              PPVRTC_G3H 3.31v
              PP5V_S5 5.08v
              PP5V_S4RS3 5.08v
              PP5V_S0 5.08v
              PP3V3_S5 3.31v
              PP3V3_S4 3.31v
              PP3V3_SUS 3.31v
              PP3V3_S3 3.31v
              PP3V3_S0 3.31v
              PP3V3_S4SW_SNS 3.31v
              PP3V3_S0SW_SSD 3.32v
              PP3V3_S4_TBTAPWR 3.31v
              PP1V8_S3 1.78v
              PP1V2_S3 1.19v
              PP1V05_SUS 1.04v
              PP1V5_S0 1.49v
              PP0V6_S0_DDRVTT 0.59v
              PP1V05_S0 1.04v
              PP1V05_S0SW_PCH_HSIO 1.03v
              PPHV_S0SW_LCDBKLT 0v
              PP15V_TBT 0v
              PP3V3_TBTLC 3.30v
              PP1V05_TBTCIO 0.98v
              PPVCC_S0_CPU 1.79v
              • kosmo
                • Sep 2014
                • 34
                • Greece
                you are right, im sorry about that.
                • kosmo
                  • Sep 2014
                  • 34
                  • Greece
                  i just noticed blown F7700, i replaced and checked with my donor panel still nothing, customer said lcd was flickering and for days and suddenly black screen, then it give the macbook to 2 different service stores, after that she brought it to me i also noticed that someone did rework on cpu it has flux around it and the protective black film burned.
                  • kosmo
                    • Sep 2014
                    • 34
                    • Greece
                    so i figured out that , from begining the problem was on lcd panel and F7700 fuse, then the guy that reworked the cpu damaged it, and the mac stopped working.
                    • mon2
                      • 14667
                      I think this will be a life sucker of a repair job.
                      May be more practical to locate another logic board of the same model and part # to repair and replace and apply the original ssd and move on.
                      This logic board is not too expensive. Often you can get lucky on eBay. I know that we picked up a non working same logic board for around $60 and got it working within minutes.
                      To replace the CPU will require a quality bga rework station. For example the ZM R7220A or R720A ( my personal choice ) but they are quite expensive. Trying to work with the manufacturer for an affordable cost for the same. But in the end you still do not know what the previous amateurs hacked up on their repair efforts.
                        HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                        This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                        09-12-2024, 02:00 PM
                      • avisonjohn
                        LG 34UM68 backlight and 'chime' on start up, but no OSD or video
                        by avisonjohn
                        I have an LG 34UM68 with board EAX66876002 but it has issues with not working correctly.
                        It powers on, backlight comes on, but there is no OSD shown, and no video shown on the screen.
                        I checked over the board for any obvious visual damage, and everything looked OK.
                        I then took a dump of the main SPI Flash chip.
                        I tried to take a dump from the EEPROM, but it would sometimes read data correctly, and other times would had obvious reading problems.
                        I managed to get a dump from it which somewhat resembled correct data - part of the...
                        10-30-2023, 09:23 AM
                        GeForce RTX2080 Super Aero video gaming card issues help need
                        This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                        Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                        05-07-2023, 08:12 AM
                        HP ProBook 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                        09-06-2024, 06:20 AM
                        HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 1000 Specification for Upgrade or Repair
                        This specification for the HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
