Dell Inspiron 5558 AAL10 LA-B843P not turn on
  • arber1232
    • Dec 2019
    • 372
    • Albania
    Hi everyone i have Dell Inspiron 55588 AAL10 LA-B843P ver 1.0 when i press power buton turn on stay for few seconds and turn of fan spining and stop .. when i put charger power light bliking 2 times .. I try to reset ,,i program bios with clear but not working ,, i change charger but is same ... I measure and voltage is ok ..19 v 3,3v 5v can i help me to resolve this problem ?
  • Sephir0th
    • Oct 2020
    • 1282
    Re: Dell Inspiron 5558 AAL10 LA-B843P not turn on
    Check voltages on all coils while pressing Power Button. And also measure Resistances to ground on all coils with Power removed.
    FairRepair on YouTube
    • arber1232
      • Dec 2019
      • 372
      • Albania
      Originally posted by sephir0th
      check voltages on all coils while pressing power button. And also measure resistances to ground on all coils with power removed.
      • arber1232
        • Dec 2019
        • 372
        • Albania
        the voltage when i pres power button is ok i have voltage but for few second
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          On page99, power sequence is given. check out which rail is not rising at all. You may need to turn on frequently.
          • arber1232
            • Dec 2019
            • 372
            • Albania
            ineed your shcematic
            • arber1232
              • Dec 2019
              • 372
              • Albania
              PM_SLP_S3# when i press power buton stay for 1 secon 3.2 and go 0 v ..PM_LAN_ENABLE is same stay for 1 sec and go 0 v...5V_S0 is ok PM_SLP_S4# stay 3.3 v....SYS_PWROK stay 1.3 v and when i pres power button go 3.2 for 1 sec an go 1.3 v,,,3D3V_AUX_KBC 3.2v ....S5_ENABLE 3.2 v....3D3V_S5 3,2 v
              • lapfix
                • Mar 2020
                • 2732
                • my workshop
                Can you take the voltage for this U3601, all pins.
                MOD Edit: Link to schematic -> https://www.badcaps.net/forum/showthread.php?t=66749
                • arber1232
                  • Dec 2019
                  • 372
                  • Albania
                  pi1-5v
                  pin2-5v
                  pin3-3.2 v for 1 sec whwn i press power button and go 0v
                  pin4-5v
                  pin5-3.2 v for 1 sec whwn i press power button and go 0v
                  pin6-3.3v
                  pin7-3.3v
                  pin 8and -when i press power buton go 3.2 v for 1 sec and stay 2 volt when light power turn off
                  pin10-2v but when i measure this pin laptop stay for 5 min tries to turn on
                  turned on and e see the cpu is work or when jum pin 9 and 10 laptop
                  pin 11-gnd
                  pin12-when i turn on go 1.1v and go for few seconds 0v
                  pin13and 14 -when i turn on go 5v for few sec and go 0v
                  • arber1232
                    • Dec 2019
                    • 372
                    • Albania
                    i turn on laptop i jump pin 9and 10..... i Discrete to UMA (i dont now what is discrete to uma but i see in youtobe ) but i think desable gpu with this trickbut i need gpuneed gpu
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      q3601-Voltage on all pins??
                      • Sametbey
                        • Jan 2021
                        • 229
                        • Turkey
                        U3601 has switch function for 5V_S0 and 3.3V_S0 after power on. Check the coil and voltage outputs for short circuits. Check components that get hot by starting frequently.
                        I'm not happy to be so strong. because it's not humanly
                        • arber1232
                          • Dec 2019
                          • 372
                          • Albania
                          no is U36o1 voltage in pin...No laptop turn on is ok but when I desabled gpu turn on
                          • arber1232
                            • Dec 2019
                            • 372
                            • Albania
                            No i not have circuits and not i have comp to geting hot
                            • cdilan88
                              • Sep 2021
                              • Sri Lanka
                              Hi did this issue get fixed? I also have the same issue.
                              • cdilan88
                                • Sep 2021
                                • Sri Lanka
                                VRAM and VCORE are not stable. any idea?
                                • arber1232
                                  • Dec 2019
                                  • 372
                                  • Albania
                                  yes i cut line gpu becouse gpu is short
                                  • davidfrank77
                                    • Sep 2017
                                    • 21
                                    Re: Dell Inspiron 5558 AAL10 LA-B843P dis to uma
                                    Finally on this ways I got my problem resolved dis to uma display.
                                    Remove two coil one capacitor near to coil and four jumpers on back side.
                                    • arber1232
                                      • Dec 2019
                                      • 372
                                      • Albania
                                      Laptop is fixed without gpu
                                      • teokarafou
                                        • Feb 2018
                                        • 23
                                        • Greece
                                        HELLO MY FRIEND,CAN YOU SHARE WHAT EXACTLY YOU DID TO USE DISAMBLE THE CPU?
                                        I DONT UNDERSTAND FROM THE PHOTO THE JYMPER YOU USED
                                        • OkSandwich1523
                                          How to edit BIOS DMI for Dell Inspiron 5558
                                          by OkSandwich1523
                                          I am new to BIOS modding but have read few guides online.
                                          I have a Dell Inspiron 5558 (I think it has AMI bios). I want to edit the BIOS's DMI info such as serial number, UUID, asset tag. I have tried using various tools such as AFUWIN, AMIDEWIN, AMIDEDOS and DMIEDIT that are posted on various forums. However, I did not have any success. All tools fail to launch or make changes to the DMI.
                                          Using AMIDEWIN, I was able to dump the DMI info, however, unable to make changes to the DMI. I even tried the using AMIDEDOS (posted here) but got error saying unable to load the...
                                          12-01-2022, 10:17 PM
                                        • shovenose
                                          Better Panel for Dell Inspiron 15-5558 Laptop
                                          by shovenose
                                          Got this for free it's pretty much the perfect laptop, with a backlit keyboard, they already upgraded to 16GB RAM and a 500GB SSD, etc. but the screen sucks - it's a 1366x768 TN panel. I'm assuming the optional upgrade panel for this model - a 1920x1080 IPS panel - will be a direct swap, but researching that it's still a fairly mediocre panel according to Notebook Review: https://www.notebookcheck.net/Dell-I....145836.0.html
                                          What I'm wondering is how specific these have to be? I've established that both the current panel and Dell FHD panel use the "Embedded...
                                          06-05-2022, 09:23 PM
                                        • YOUCEF4787
                                          Installation Issue with AMD Radeon 520 Graphics Drivers on Dell inspiron 15 3576
                                          by YOUCEF4787
                                          I am writing to seek assistance regarding a problem I encountered while attempting to install the AMD Radeon 520 graphics drivers on my Dell Inspiron 15 3576 laptop running Windows 10.
                                          Upon installing the graphics drivers, my system freezes, and I am left with a black screen. Unfortunately, this issue has prevented me from utilizing the full capabilities of my AMD Radeon 520 graphics card.
                                          Laptop Model: Dell Inspiron 15 3576
                                          Operating System: Windows 10
                                          Graphics Card: AMD Radeon 520
                                          Steps I have taken:
                                          Downloaded the latest AMD...
                                          07-08-2023, 05:23 AM
                                        • tariom18m
                                          Dell inspiron 5415 bios Password
                                          by tariom18m
                                          Dell Vostro 5415 bios Password MOD EDIT: INSPIRON 5415 NOT VOSTRO
                                          Hi could anybody help me with removing bios password please or supply clean me bios for Dell Vostro 5414 MOD EDIT: INSPIRON 5415 NOT VOSTRO
                                          Système disable
                                          5B8336EF14B92F31
                                          SERVICE TAG
                                          5ZYRHG3
                                          Thanks in advance
                                          10-23-2023, 01:05 PM
                                        • pabloroggeri
                                          Dell inspiron 3421 that distortion on the screen
                                          by pabloroggeri
                                          Dell inspiron 3421
                                          Mother DNE40-CR MB.
                                          Good guys.
                                          I have this problem with this Dell notebook, it has that distortion on the screen as you can see in the photo. has it ever happened to you?
                                          I present the tests and measurements that I already did:
                                          I tried with another screen and it does the same thing, I also put this screen on another one and it looks perfect.
                                          I checked the LVDS flex that goes to the display and it is perfect
                                          Through HDMI output the image looks perfect
                                          All power lines were measured...
                                          09-29-2023, 06:46 AM
