Macbook Pro A1297 Unibody 2009..No Power
  • Joandaz
    • Feb 2021
    • 10
    Hi members new here to Badcaps and new to board diagnostics
    The unit unit will not power up.
    Mac Board 820=2610=A
    The connected mag safe shows a green led
    Have removed the logic board,no visible sign of cap damage,or liquid spill.
    I have measured the fan jack J5650 and J5660 at pin 1
    No voltage so I believe we have a PP5V_S0 rail issue
    Schematics PP3V3_S0 identifies the mosfet Q7930 6 Pin should have 4 legs 1,2,5,6 at 3.3 volts.
    Measuring zero volts on these legs
    Legs 3,4 are powered and measure 3.3 volts from the PP3V3_S5 and PP3V3S0_SS.
    Am I able to conclude that the mosfet is faulty and is the source of the problem.
    Please guide this nube
    Very new at troubleshooting..please excuse my ignorance
    Common issue Tantalum Cap C771 was tested good.
  • mon2
    • Dec 2019
    • 14671
    Re: Macbook Pro A1297 Unibody 2009..No Power
    Welcome.
    What are the readings on each leg D6905?
    Also post the values for the 2nd attached graphic.
    • Joandaz
      • Feb 2021
      • 10
      Originally posted by mon2
      Welcome.
      Thanks Mon,I edited the post as I was stupidly reading the wrong schematic the rail PP5V_S0 at pin 1 on the fan connector reads zero volts..Will look at your thumbnail and come back...thank you
      • Joandaz
        • Feb 2021
        • 10
        Welcome.
        Mon, thank you here are the measurements
        Diode D6905
        Voltage ground to leg 1 is 18.95v
        Voltage ground to leg 2 is 8.67v
        Voltage ground to leg 3 is 18.67v
        Resistor R6911
        Leg 2 of the resistor to test point TP1 PP18V5DC in onewire 11.08 V
        TP1 PP18V5DC to TP1 Onewire Pwr En L Div 19.1 V
        • piernov
          • Jan 2016
          • 4439
          • France
          Even if it looks good, C7771 should be replaced nonetheless.
          No point in troubleshooting one-wire circuit and charging circuit if green light and S5 rails are present.
          As all MacBooks with NVidia MCP, power button must be triggered to turn on the machine.
          And as always when troubleshooting a power issue, the list of power rails must be followed to measure voltage on every power rails.
          • Joandaz
            • Feb 2021
            • 10
            Thank you Pernov...Louis Rossmann has a great Youtube clip on understanding power rail sequence..I have no power on the PP5V_S0, together with a number of shorted caps on the PPVCORE_S0...do you think it would be ok to inject a low voltage and current into the rail to find the shorted component
            • mon2
              • Dec 2019
              • 14671
              Please post the resistance to ground on these rails.
              It is common for low readings for the vcore (low voltage) rail.
              • Joandaz
                • Feb 2021
                • 10
                Thanks Mon
                Resistance to ground readings
                Pin 1 Fan jack PP5V
                J5650 is 1.4 M ohms
                J5660 is 1.2 m ohms
                Vcore caps C7562 C7568 C7564 are 4.0 ohms
                • mon2
                  • Dec 2019
                  • 14671
                  Hi. What is the resistance to ground on PP3V3_S0_FET?
                  Q7930 may be damaged.
                  • Joandaz
                    • Feb 2021
                    • 10
                    Evening Mon, whilst checking the voltage on the Fet Legs Q7930 PP3V3_SO the PPBUS_G3H Fet Q4260 started to fry..cap looks burnt too
                    Will have to source a donor board and come back to you
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 674
                      What Piernov said, I would start out replacing C771 first with the proper Tantalum Cap. Usually in MOST cases this solves the no power issue for these 2009 boards. Once that is replaced also double check your power button works.
                      We replaced a bad cap on this board and still had no voltage when we pressed the power button, we used a temp Keyboard and voila it turned on. Just make sure you do that as well, it seems to be common for these boards to fail with that cap and in some cases the cap is bad and the power button fails as well. Hope this helps.
                      sigpic
                      MEOWING IN THE IMPOSSIBLE UNIVERSE!
                      • tata123
                        • Nov 2013
                        • 104
                        check if SMC is OK, put your Battery on and off, if LED turn from Green to Orange, if this is ok, check rails and post here!!
                        • Joandaz
                          • Feb 2021
                          • 10
                          I continue to wade through the schematics to find why the PP5V_S0 rail is missing.
                          I understand that PP5V_S0 is generated from U7500
                          I am not seeing a voltage on P5V RTS0_EN and tracing the output back to PM_SLP_S4_L
                          Am I chasing rabit holes?
                          • mon2
                            • Dec 2019
                            • 14671
                            What are the voltage readings for the following rails (3 of them) as per attached table?
                            • Joandaz
                              • Feb 2021
                              • 10
                              Mon ..thank you again
                              PM_SLP_S4_L no voltage at Q7912
                              PM_SLP_S3_L 3.32 v at Q3801
                              SMC_PM_G2_EN 3.38 v at TP(1)SMC_PM_G2_EN
                              Directions out of the burrow please
                              • mon2
                                • Dec 2019
                                • 14671
                                PM_SLP_S4_L appears to be linked to U1400. Wonder if that is defective but too early to tell.
                                Can you post the readings for the attached points of interest?
                                • Stephen
                                  Meow Meow MEOW!
                                  • Apr 2020
                                  • 674
                                  Ouch U1400 doesn't sound pleasant. Dead CPU no bueno. Not worth repairing at that point. You could buy a no power logic board on eBay with a failed CAP for next to nothing and just replace the cap and have a working board.
                                  sigpic
                                  • piernov
                                    • Jan 2016
                                    • 4439
                                    • France
                                    PM_SLP_S4_L should come up at the same time or before PM_SLP_S3_L.
                                    U1400 is the MCP.
                                    • Joandaz
                                      • Feb 2021
                                      • 10
                                      Mon little confusing between schematics and board view.
                                      PP3V3_S0_P3V3S0FET on the board view measured between R7932 PIN 1 and C7931 Pin 1 board view shows rail PP3V3_ S5 at these components
                                      If correct PP3V3_S0_P3V3S0FET location 1 measures 0 volts
                                      P3V3S0_EN Pin 5 Q7912 location 2 measures 0 volts
                                      PP3V3_S0_FET Pin 6 Q7930 location 3 measures 0 volts
                                      P3V3S0_EN_L location 4 measured between R7930 Pin 2 and R7930 Pin 1 measures 3.28 volts
                                      Trust this makes some sense
                                      Losing confidence my end
                                      • Stephen
                                        Meow Meow MEOW!
                                        • Apr 2020
                                        • 674
                                        U1400 is the MCP.
                                        Oops I got the U1400 backwards with a Mid 2009 13" cpu
                                        sigpic
