HP Pavilion 15 (R62) not powering on with charger
  • classicandy
    • Apr 2018
    • 308
    • Nigeria
    Please, i need help with my HP Pavilion 15 (R62). It's not powering ON with the charger only. But it powers On and display with Battery and charger connected or battery Only connected.
    It charges the battery normally though.
    I noticed it gets abnormally hot around PL11 (Coil), PQ29 and PQ32. And there's a voltage drop at PL11. With battery and charger connected, my multi-meter reads 12.89 volts entering it from Charging IC (PU5) and 12.77v leaving it to +BATCHG.
    I've replaced PL11 and still same problem. I have also replaced PU5 just in case it might be faulty, yet no luck.
    I have attached my multi-meter voltage readings of PU5 and some additional pics.
    Thanks in advance.
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: HP Pavilion 15 (R62) not powering on with charger
    find out AD_ID voltage on R499 R501 SIO pin 64 ?
    • classicandy
      • Apr 2018
      • 308
      • Nigeria
      R499 = 0.46v
      R501 = 0.46v
      SIO pin 64 = 0.46v
      • Techtiger
        • Oct 2014
        • 1601
        • france
        Originally posted by classicandy
        R499 = 0.46v
        R501 = 0.46v
        SIO pin 64 = 0.46v
        With a 45W charger AD ID 0.46V perfect did you try with a different charger is the DC jack light in on ?
        • classicandy
          • Apr 2018
          • 308
          • Nigeria
          Haven't tried with a different charger yet. DC Jack light comes on
          Without battery: White
          With battery: Amber
          • Sametbey
            • Jan 2021
            • 229
            • Turkey
            Would you check
            I'm not happy to be so strong. because it's not humanly
            • classicandy
              • Apr 2018
              • 308
              • Nigeria
              Originally posted by Sametbey
              Would you check
              In mine,
              Pin 15 = 1.88v
              Pin 18 = 16.66v
              The remaining pins are of the same values as the values in the picture you posted.
              I don't have an Oscilloscope yet.
              • Sametbey
                • Jan 2021
                • 229
                • Turkey
                the battery is charging. If the problem is not starting the notebook, is your Stby voltage 3.3v? Program bios if there is 3.3v (PU9).
                • classicandy
                  • Apr 2018
                  • 308
                  • Nigeria
                  by Stby voltage (Standby), which pin are you referring to?
                  PU9 Pin 6 = 3.3v present
                  PU10 Pin 6 = 5v present
                  But I noticed there is 0.86v on PL24 when the system is in off state but connected to either charger, battery or both. When switched On (on battery), it goes to 5v.
                  • classicandy
                    • Apr 2018
                    • 308
                    • Nigeria
                    Will reprogramming of the BIOS solve the issue of the charging section getting very hot?
                    I suspect a partial short or damaged component somewhere around the charging section but i can't pinpoint it yet.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      PQ35 Voltage on G-S-D??
                      • Sametbey
                        • Jan 2021
                        • 229
                        • Turkey
                        Warming in the charging circuit will not be resolved with the Bios program. PQ35 is the battery switch, n-mosfet. With the adapter + battery there should be D 19v, S 12.6v, G 3.3v. When the adapter is removed, D 12.6v, S 12.7v, G 25v.
                        SIO pin 64 = 1,5v need to be
                        • classicandy
                          • Apr 2018
                          • 308
                          • Nigeria
                          Voltage on PQ35
                          Without Adapter
                          D = 11.97V
                          S = 11.97V
                          G = 18.05
                          With Adapter
                          D = 19.66V
                          S = 12.68V
                          G = 12.67V
                          • classicandy
                            • Apr 2018
                            • 308
                            • Nigeria
                            SIO Pin 64 @ 1.5v seems unlikely to me. 0.46v seems to be the right value for AD_ID using 45W Adapter usually on most HP Laptops
                            • classicandy
                              • Apr 2018
                              • 308
                              • Nigeria
                              Any ideas on this????
                              • Sametbey
                                • Jan 2021
                                • 229
                                • Turkey
                                The voltage on the PQ35 is also ok. + 5v ALWV can come off after start.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Try with 65W Adapter. This unit requires 65W atleast and not 45W afaik.
                                  • classicandy
                                    • Apr 2018
                                    • 308
                                    • Nigeria
                                    I guess this is it. The unit finally came on with a 65W adapter. BUT still gets hot but NOT as hot as when a 45W adapter was being tested with it. Thanks.
                                    • classicandy
                                      • Apr 2018
                                      • 308
                                      • Nigeria
                                      Oh, i forgot to mention, this unit is "DIS". So maybe using a 90W adapter won't make it get hot as it used to. Maybe just a little warm I guess.
                                      It didn't even occur to me, maybe because I was working along side with that of a "UMA" unit. Meanwhile, that UMA unit is still faulty but I'll open a new thread for that.
                                      • classicandy
                                        • Apr 2018
                                        • 308
                                        • Nigeria
                                        Special Thanks to @techtiger, @sametbey and @mcplslg123 for your support.
                                          HP Pavilion Pavilion p6560be-m Desktop PC Bundle Pavilion p6500 E6600 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion p6560be-m Desktop PC Bundle can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6560be-m Desktop PC Bundle boardview and Pavilion Pavilion p6560be-m Desktop PC Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 03:44 PM
                                          HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
