Dell XPS 13 9360 No charge
  • Andreasbest
    • Aug 2014
    • 1193
    • Hellas ( Greece )
    Hello.
    I have a XPS 13 on the bench that doesn't charge.
    The jack seems fine as i put a needle on center pin and it doesn shortcircuit with the pin 3 that is PSID.
    Now, not sure if this is a real problem but i looked on PL102 and nearby is a tiny black SMD that looks bent and/or cold soldered (perhaps a diode?)
    I marked it with a red rectangular in one of the photos, unfortunately it's impossible to take a more clear picture as it's extremely tiny.
    What do you suggest?
    Schematics attached.
    Thank you in advance!!
  • khaahk
    • Dec 2013
    • 806
    • Estonia
    Re: Dell XPS 13 9360 No charge
    It turns on but does not charge the battery? Then look towards charger circuit (PU300).
    • Andreasbest
      • Aug 2014
      • 1193
      • Hellas ( Greece )
      Yes turn on but doesn't recognize the adapter's wattage and therefore doesn't charge.
      Seems like the PSID is broken somewhere.
      What should i look at PU300?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        pr103 Checked??
        • Andreasbest
          • Aug 2014
          • 1193
          • Hellas ( Greece )
          pr103 Checked??
          Goodmorning!
          Where is it? Can't find it.
          • khaahk
            • Dec 2013
            • 806
            • Estonia
            If charger is not recognized then its not about PU300.
            PR103 is most likely near the PQ100.
            • Andreasbest
              • Aug 2014
              • 1193
              • Hellas ( Greece )
              Near PQ100 i see one black resistor that has continuity in both pin.
              Right above the PQ100 though is the black SMD i mention in first post that looks weird, is not straight and on bottom pin i see the PSID but not on the top.
              Check the picture, is very close
                • 21525
                The black SMD part is PD102
                • Andreasbest
                  • Aug 2014
                  • 1193
                  • Hellas ( Greece )
                  A diode? So it's regular to see PSID on one pin but not on the other, correct?
                    • 21525
                    PD102 is a TVS diode .
                    • Andreasbest
                      • Aug 2014
                      • 1193
                      • Hellas ( Greece )
                      Sorry for my ignorance but that means it's behaviour is ok or should i do something?
                        • 21525
                        Its ok ,probably been replaced before. PR103 is connected to PQ100 pin 3 according to the schematic. It should measure 33 Ohms. Test the voltage as well .
                        https://cdn.badcaps-static.com/pdfs/...6c55fee955.pdf
                        • Andreasbest
                          • Aug 2014
                          • 1193
                          • Hellas ( Greece )
                          I think is this (red rectangle), no sign of PSID in either pins, haven't check voltages yet.
                          Is this the PR103 though?
                          • Andreasbest
                            • Aug 2014
                            • 1193
                            • Hellas ( Greece )
                            I checked voltages on PQ100 too
                            I only see 5V on gate pin and 0 at drain.
                            I check only the motherboard, without battery connected by the way.
                              • 21525
                              Remove PD102 and see if the voltage comes up .Test resistance to ground as well, before and after removing PD102. Try another DC-IN jack .
                              • Andreasbest
                                • Aug 2014
                                • 1193
                                • Hellas ( Greece )
                                Top pin of PD102 is shorted to ground with and without the diode on it.
                                Without PD102 i got 3.3v at drain and source too!
                                  • 21525
                                  The board will run without PD102 but its better to get a replacement as its there for protection.It most likely shorted because a non genuine poor quality charger was used.
                                  Have you done the other check on PR103 as suggested by other members.Also check the voltage on both pins.
                                  • Andreasbest
                                    • Aug 2014
                                    • 1193
                                    • Hellas ( Greece )
                                    If PR103 is the one directly connected to source of PD102 it has 3.3v on both pins
                                      • 21525
                                      Check if the battery charges now .
                                      • Andreasbest
                                        • Aug 2014
                                        • 1193
                                        • Hellas ( Greece )
                                        Yes it charges all good.
                                        Problem is that i can't find AZ5125-01H anywhere in EU and my donor pcbs don't have any on them.
                                        Does anyone have one? I'll pay the shipping cost!
                                          DELL XPS 9360 Notebook 13 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 9360 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9360 boardview and 9360 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9360 Notebook...
                                          09-06-2024, 04:00 PM
                                          09-06-2024, 06:06 AM
