Can we "force" a "wake" on a laptop battery ?
  • Acnologia
    • 428
    • Poland
    Hello!
    Question about friends laptop ,works great Lenovo E560 ,all good all fine. The battery is with 98,9% health percent, with BatteryInfoView, but it doesn't charge.
    We tried another battery (from my laptop and it charges just fine).
    So the problem is with the particular Battery.
    My question , and my thinking is (some cell might have died and the controller just suddenly takes it off) , so i was thinking if i can "ground" her or "force" some juice inside ,just to wake up the controller ?
    (It's silly i know,but it's shame for a good battery to be dead,and it's expensive).
    So that is my question ? (Maybe the Multimeter to be put into left / right corners for + / - ,wake up with the - ground to another pin to count the voltage,and then put the bench supply into +/- and put the battery into shake mode.
    • 21874
    Re: Can we "force" a "wake" on a laptop battery ?
    Whats the battery FRU part number. Is your laptop model the same E560 .Try the Lenovo Battery Firmware Update Utility
    https://support.lenovo.com/us/en/dow...it-xp-thinkpad
    • serious_electron
      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
      by serious_electron
      Hello Everyone!
      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
      06-28-2025, 02:57 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • ahmarzo
      Acer TMX314-51 laptop battery problem
      by ahmarzo
      I have acer laptop tmx314-51 with part no 6050A3020501.
      The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
      But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
      I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
      The schematic is not available...
      04-11-2025, 09:14 AM
      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
      Narrow VDC applications where the system power source is
      either the battery pack or the regulated output of the charger.
      This makes the max voltage to the system equal to the max
      battery voltage instead of the max adapter voltage. Operating
      at lower system voltage can improve...
      11-05-2024, 04:43 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
