Lenovo C340 El5c3 el531 el431 la-h101p_lo2 problem
  • A1yn88
    • Mar 2014
    • 111
    • Romania
    Hello everyone, I have attached a diagram for Lenovo C340. I got one in the service with spilled fluids. Initially it was taken to another service where the BIOS was changed, of course it didn't work. The problem is that, although I bought the electronic schematic, I can't figure out why I'm missing + VCC_GT, 0V. If anyone can help me, I would appreciate it. Thanks.
    Schematic - https://www.badcaps.net/forum/showthread.php?t=91821
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Lenovo C340 El5c3 el531 el431 la-h101p_lo2 problem
    If ram section is ok check pin 20 of Pu 501
    Check vcc_sa voltage then
    vcc_core
    Vcc_gt is s0 state high voltage means full on laptop
    • A1yn88
      • Mar 2014
      • 111
      • Romania
      vcc_sa = 1.010 v
      vcc_core = 0.890 v
        • 21922
        Have you checked PUG1 and PQG1
        • stingerchamp
          • Sep 2020
          • 425
          • Pakistan
          Check enable pin1 2.5 and pin 8 vcc 5v is coming at RT9610CGQW_WDFN8_2X2 which is generating vcc GT pug1
          En pin and vcc both are connected to power on reset logic inside ic and if one goes low output will be low
          If enable is low check driven_set is coming out correctly at voltage divider pr272 and pr275
          Last edited by stingerchamp; 01-07-2021, 10:16 AM. Reason: Read schematic found ic and read it's requirements
          • A1yn88
            • Mar 2014
            • 111
            • Romania
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              First check driven_ set at voltage divider pr275 and pr272
              Driven_set must be 2.5v check
              Then at core ic puz1 carefully check pin 35 voltage it is driven coming here
              Ic will start working when driven is available in threshold
              • A1yn88
                • Mar 2014
                • 111
                • Romania
                pin 35 = 5V
                • stingerchamp
                  • Sep 2020
                  • 425
                  • Pakistan
                  Check drven_,set at voltage divider
                  correction
                  prz72 and prz75
                  If 5v then floating is enabled to ps4
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    Check prg1 which is 2.2 ohm with 5 percent tolerance
                    Check pcg1 boot capacitor which is 0.1uf
                    Enable is ok , vcc ok but pqg1 gate is disabled because ugate supply is missing , boot is the supply for ugate mosfet ,boot supply is not reaching ugate .
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      What is the actual issue with the machine?
                      • A1yn88
                        • Mar 2014
                        • 111
                        • Romania
                        No video signal, some liquid was spilled.
                        PRG11 - 2.5 ohm
                        PCG12 - 0.1 uF
                        prz72 and prz75 - I don't know where is on the board.
                        So, the conclusion is the PUG3 is defective because boot supply is not reaching ugate?
                        • Sephir0th
                          • Oct 2020
                          • 1289
                          Try to Follow Pin 18 of PUZ1 to find them. They are connected on +5VALW/ Rail.
                          FairRepair on YouTube
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            Did you check if it's POSTing at least?
                            If it was liquid damaged you have hints to follow…
                            • A1yn88
                              • Mar 2014
                              • 111
                              • Romania
                              How to check if it's POSTing?
                              • A1yn88
                                • Mar 2014
                                • 111
                                • Romania
                                PRG11 - 2.5 ohm
                                PCG12 - 0.1 uF
                                Sorry
                                PRG1 / PCG1 / PUG1
                                • Sephir0th
                                  • Oct 2020
                                  • 1289
                                  Put external Keyboard and Test If CapsLock works.
                                  • A1yn88
                                    • Mar 2014
                                    • 111
                                    • Romania
                                    Not working
                                    • A1yn88
                                      • Mar 2014
                                      • 111
                                      • Romania
                                      Driven_set = 0V
                                      • stingerchamp
                                        • Sep 2020
                                        • 425
                                        • Pakistan
                                        Driven_set 0 is ok because look in schematic @ sign at prz72 means resistor is not populated, only prz75 populated which is connected to ground
                                        Correct me if I am wrong
                                        Core voltage is ok , vccsa is ok
                                        Fault is around pug3
                                          Lenovo IdeaPad C340 Hybrid (2-in-1) C Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad C340 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C340 boardview and C340 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad...
                                          09-06-2024, 04:10 PM
                                          09-06-2024, 04:00 PM
                                          Lenovo C340 Chromebook Specification for Upgrade or Repair
                                          This specification for the Lenovo C340 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C340 boardview and C340 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo C340 Chromebook...
                                          09-06-2024, 03:30 PM
