replace 8600nvidia with radeon HD 3470
  • Petrakis796
    • Nov 2020
    • 7
    • Greece
    Hi to all
    I would like to ask the following
    I have an Acer 5920 G and i want replace 8600 G86-770-A2 with radeon HD 3470
    The supplier says it is possible but I have read that it may need to be updated to bios
    My problem is that the card 8600 is completely dead (black screen) and if I need updated the bios if i use HD 3470 how will I do it?
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    Re: replace 8600nvidia with radeon HD 3470
    5920G has MXM slot. But you can never know if it will be compatible with other card.
    Maybe the best bet is to bake the Nvidia 8600.
    Long time ago, I did it with IR termometer, radiator from a GPU cooler and gas soldering iron, used as a small torch.
    You can also try to reflow it with hot air gun.
    Heating the radiator to spread the heat evenly and controlling with the themometer not to burn anything. After baking at 250C it worked. Just preheat and do the heating and allow to cool down gradually.
    Or ask some computer repair shop if they have working 8600 and can update your bios. But replacing the bios can also brick the laptop. It depends so much, even with MXM, laptop GPU-s are not interchangeable, unless they are specifically mentioned in the BIOS whitelist.
    My procedure was heating with hair dryer, put the metal block, heat gradually up to 245-250, then gradually let it cool down. Dont move the mobo until it cools down to room teperature. Back then I did not have temperature controlled hot air station, neither temperature controlled soldering iron and etc. It was about 12 years back. This is why from this point in the past, I buy only laptops with integrated in the chipset/cpu Intel Graphics. They are not powerful, to say at least, but never fail in such a manner.
    Unless you can get other GPU dirt cheap, it is not worth the effort. The specs are low. For 150EUR you can buy core i5 with 4GB RAM and SSD.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
    • Petrakis796
      • Nov 2020
      • 7
      • Greece
      thanks for the reply
      Ι understand that such a replacement is questionable and dangerous
      I will probably get one exactly the same (8600 G86-770-Α2) refurbished from ebay to be sure as far as not to change the bios
      • televizora
        ghettomodmaster
        • Nov 2016
        • 957
        The price of the the card in ebay is about 1/3 of another laptop with core i5, 4GB RAM and 250GB SSD. And this is not including the shipment of the card. Just sell if for parts and buy another laptop. And you cant be sure if the one you intend to buy from ebay is not defective as well.
        It just doesn't worth the effort to repair this laptop.`
        You can get about 25-30EUR for the screen, 10EUR for the keyboard, 10-20EUR for the HDD and another 15-20EUR for the plastics and WLAN card.
        Even if you replace the card, the replacement may die as well. The whole 84/86 series are defective to some extend.
        And for 150EUR you can buy much newer laptop, with newer hardware, more memory and if you are lucky, even SSD.
        • piernov
          • Jan 2016
          • 4439
          • France
          If you want to get a bit more life out of it just heat to 200°C max (if you go above you risk damaging the balls or completely killing the GPU) for a minute and a half (no flux), it should bring it back to life for a short time. Of course the GPU is dead and it'll fail again.
          Also if you get the same GPU then it'll have the same issue. You have to get one with the fixed revision of the GPU (white underfill around the die). But of course most stuff you'll find on eBay/Aliexpress will have the defective GPU (dark underfill around the die), it'll most likely have been baked already and will fail again soon enough.
          As for replacing the graphics card with another model, it's possible, but this series of Acer laptop is known to have a lot of compatibility issues with MXM cards due to poorly written BIOS. In general you'll need a specific VBIOS on the card and/or a patched BIOS on the laptop to have them work properly.
          A good replacement would be the 9600M GT but you need to flash a patched BIOS, see http://forum.notebookreview.com/thre...00m-gt.575866/ .
          The ATi Mobility Radeon HD 3000 series could work but I think it requires a specific VBIOS. If the seller does not know about it then I would not recommend it. Also the Radeon HD 3000 series still has a kinda high failure rate (nowhere near the NVidia GPU from 2006-2008, but it's still not unusual to find them dead).
          • Askic
            • Sep 2018
            • 187
            • BIH
            Can you please explain this in more details? If the GPU is defective (dead), how heat will revive it? Some internal broken connection will be connected again or what? I understand that heat can make better solder joint, but how will it work inside the chip? I know this works, but I don't know why if solders are not the culprit.
            This is something I don't really understand (the physics behind it).
            Thank you.
            • piernov
              • Jan 2016
              • 4439
              • France
              Look for NVidia "bumpgate" related articles on SemiAccurate, The real issue of these chip is actually explained (it's a combination of wrong underfill material, wrong bump material and heat dissipation). I haven't seen an analysis on why heat affects the GPU though, but we could speculate that it has to do with softening the underfill and the bumps.
              • Petrakis796
                • Nov 2020
                • 7
                • Greece
                First of all, thank you all for the usable ideas you gave me
                but I prefer the upgrade to the card 9600
                My problem is how can flash the pached bios with black screen ?
                Is there the pached file in a file for example bin? so i can buy a empty bios chip from ebay and then program it and replace with it the bios chip that my motherboard has now?
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1866
                  Just wanted to chime in and say that some of these shipped with ATI cards.
                  It will support 3450/3470/3650 as well as 4650 out of the box.
                  I have bought an 5920G with a defective 8600M GT and have easily replaced it with a 4650. The only requirement is for the card to be a Acer OEM'd card - usually these have a VG tag on them:
                  3470 - VG.82M06.003
                  3650 - VG.86M06.003
                  4650 - VG.M9606.006
                  Main rig:
                  Gigabyte B75M-D3H
                  Core i5-3470 3.60GHz
                  16GB DDR3-1600
                  Samsung SH-224AB DVD-RW
                  Delux MG760 case
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    Hence the specific VBIOS requirement.
                    • Petrakis796
                      • Nov 2020
                      • 7
                      • Greece
                      As for the 9600 card, does anyone have any idea to successfully place it on my laptop that has a black screen?
                      • zunasthegreat
                        • Dec 2017
                        • 92
                        • EU
                        I have already fixed 2 5920G from the dissasterous G84/G86 mxm cards. The cheapest solution was to buy an acer hd 3470 card from aliexpress for 20-25€.
                        Wouldn't spend a penny more for a 12y old laptop. If u go that route you will need a copper shim of 1mm I think so the heatsink can touch the ATI die.
                        Just search for acer hd 3470 and you will see many results, just have some patience.
                          AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                          The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                          10-01-2024, 12:46 PM
                          AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                          The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                          10-01-2024, 01:07 PM
                          AMD Radeon RX 470 / RX 580 Schematic & Board View
                          The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
                          10-01-2024, 12:52 PM
                          AMD Radeon R7 340 / R7 430 Schematic & Board View
                          The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
                          10-01-2024, 12:36 PM
                          AMD Radeon RX 7900 XT (RX7900XT) Schematic & Board View
                          The Radeon RX 7900 XT is an enthusiast-class graphics card by AMD, launched on November 3rd, 2022. Built on the 5 nm process, and based on the Navi 31 graphics processor, in its Navi 31 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 7900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 31 graphics processor is a large chip with a die area of 529 mm²...
                          10-01-2024, 12:20 PM
