HP Probook 4540S No Display
  • battery.12v
    • 123
    • NW
    Hello Guys, HP Probook 4540s Discrete, No Display, Caps lock blink 5 times ,PLTRST# is high and All Voltages are OK except GFXCore and i think thats ok, as it wont rise up before POST, any idea or guidance ? ...
    Flashed Bios but nothing changed, Changed CPU also but no luck
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: HP Probook 4540S No Display
    You need oscilloscope to check PCH crystal xtal is ok or not , 24 MHz clock coming
    • battery.12v
      • 123
      • NW
      Sorry but i dont have oscilloscope, i tried to convert it from Dis to UMA but same problem 5 times blinking
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Check bios pin 1 chip select
        But with DSO only
        CPU is dead if CS is ok and pltrst#is 3.3v or high
        • battery.12v
          • 123
          • NW
          But with DSO only
          do you mean by DSO a digital oscilloscope ?
          i changed CPU with three different ones and same problem
          PLTRST# is 3.3v
          CS is 3.3V i dont have OScilloscope
          could Someone provide me with a trusted working bios
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            Yes digital storage scilloscope
            PCH communicates with bios chip not ec bios
            With chip select C's pin 1
            First with oscilloscope check crystal is having frequency or not at 10x probe
            and clock is ok or not
            Pltrst# means PCH is ok at power level only
            • battery.12v
              • 123
              • NW
              as i dont have an oscilloscope, can you tell me what are the consequences of a working CRystal Clock VS non Working one, as i can just replace it blindly
              • stingerchamp
                • Sep 2020
                • 425
                • Pakistan
                To make sure ram section is ok and
                CPU is sending dramrst# signal , check dramrst#
                Rtc section 32 khz clock is necessary for imp PCH communication
                CMOS cell provides 3.3v supply to crystal 32 khz oscillator , here I am talking about in general
                In new motherboards now more data hunger devices so
                PCH has many oscillator working inside it , PCH has blue clock 14mhz , 24mhz etc. In schematic it is written as xtal in ,xtal out 4 legs Epson body ic
                PCH gets this clock signal and boost its frequency to generate many frequency signals for audio, HDD etc
                Detail is boring lol
                PCH communicates with sio
                Sio has ec bios which it reads for instructions to process and run diff device etc
                Without crystal oscillator laptop will not work or no display
                as no PCH communication, you flash bios or not does not matter if no clock
                Without CMOS battery or cell , laptop will start and function but not in normal way
                Last edited by stingerchamp; 12-27-2020, 04:58 AM. Reason: More info but can not short it
                • battery.12v
                  • 123
                  • NW
                  DramRST# is 1.53V so its okay if im not wrong
                  should i change the PCH crystal ?
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    Dram reset is ok ,PCH is ok as pltrst# is ok
                    Now comes bios check
                    At pin 8 bios 3.3v and some voltage on bios C's
                    If this is ok means everything is ok except gfx
                    Have you checked flashing EC bios
                    and PCH bios
                    To check bios is communicating we need clock signal on xtal crystal oscillator
                    Since we don't have oscilloscope
                    just check pin 1 of bios chip of PCH bios (main bios located near PCH)
                    If ok
                    Programme the KBC using vertyanov or svod if KBC is programmable
                    5 beep issue will get resolved
                    • battery.12v
                      • 123
                      • NW
                      and PCH bios
                      If ok
                      i appreciate your support bro
                      i flashed bios but no luck and KBC is not PRogrammable
                      3.3V is present in pin 8 of Bios Chip
                      • stingerchamp
                        • Sep 2020
                        • 425
                        • Pakistan
                        Check CPU core voltage generating when on
                        Check vr-on signal
                        CPU is ok if core voltage ok
                        Can you make this Uma from discrete
                        • battery.12v
                          • 123
                          • NW
                          Check vr-on signal
                          CPu Vcore is 1.1V
                          VGate is 3.3V
                          yes i converted it to UMA by removing Coil but Same PRoblem
                          • stingerchamp
                            • Sep 2020
                            • 425
                            • Pakistan
                            Check following signals
                            Dram_pwgood
                            Dram_powerok
                            Imvp pwrgood
                            CPU pwgd
                            Vr_on from kbc
                            Ck_pwgd. Clock
                            Do you have schematic?
                            When you check crystal oscillator
                            Remove it it should not beep with each other pins
                            Change 24mhz crystal near PCH
                            Check 1.05 PCH supply just in case before removing
                            If CPU core voltage is ok
                            Last step check hwpg or
                            All sys power good
                            When PCH receive EC power ok signal and
                            When CPU gets dram power ok and CPU pwrgood and pltrst # from PCH, considering clock is ok then PCH will enable chip select pin of main bios and CPU will start interfacing with bios
                            I am not an expert but sharing what I know
                            My full support is to save your motherboard
                            Your PCH is ok
                            Your CPU is ok
                            Your KBC is getting ref clock of PCH at LPC ?
                            For GPU , discrete to Uma
                            First make sure you removed resistor which tells graphic card is present
                            Then remove coil
                            • battery.12v
                              • 123
                              • NW
                              Dram_pwgood
                              Dram_powerok
                              Imvp pwrgood
                              CPU pwgd
                              Vr_on from kbc
                              Ck_pwgd. Clock
                              All sys power good
                              Your PCH is ok
                              Your CPU is ok
                              Then remove coil
                              CPu is ok, 25Mhz Crystal PCH is ok, Pltrst# is ok, All SystemPwGood is Ok, DramRSt# is ok, Cpu Vcore is ok, flashed Bios three times and no luck, changed Bios chip no luck
                              inserted a Debug Post Card and it gives me just 0
                              conserning UMA conversion all guides just instruct to remove only Coil
                              • stingerchamp
                                • Sep 2020
                                • 425
                                • Pakistan
                                If PCH is getting same signal that GPU is present
                                It will not switch display to lvds
                                If you have schematic,
                                You will sea board_id or vga_id or vram_id table
                                To convert to Uma
                                You need to change board id according to table
                                To change board id it will ask to remove or shift resistor to another place so that PCH gets signal that GPU is not available
                                It can be high logic 3.3v pull up or low pull down ground
                                After this if you remove coil PCH will shift display but it depends on board to board
                                In old board we also had to change clock and data lines for lvds to pch
                                Post card I do not have experience
                                But reset light will turn on and off one time
                                How are you measuring signals if you don't have schematic
                                • battery.12v
                                  • 123
                                  • NW
                                  To convert to Uma
                                  this is the schematic
                                  • battery.12v
                                    • 123
                                    • NW
                                    Client Took his laptop unfortunatly
                                    • stingerchamp
                                      • Sep 2020
                                      • 425
                                      • Pakistan
                                      Oh
                                      Too late I guess
                                      But anyhow
                                      Do you want to get knowledge how to convert any laptop to uma
                                      • lapfix
                                        • Mar 2020
                                        • 2765
                                        • my workshop
                                        Oh
                                        Too late I guess
                                        But anyhow
                                        Perfect analysing , YES for all type of knowledge
