Re: HP Probook 4540S No Display
In old boards there used to be separate lvds switch for display
But in new boards lvds connector is directly interact with PCH
Goal :. To convert everything from GPU to pch and cut connection of GPU with PCH
For this every motherboard has nodes alignment specified
For example in this board mention here (schematic ) although if you type Uma in search bar it will pinpoint location need to be changed
Only crt is connected to GPU and lvds is connected to PCH directly and hdmi is also connected to PCH
Also at lvds connector clock and backlight control and data is interlinked with PCH
In this board we just need to change vram id
Vram id or board id
How ?
First step :Replace position of resistor so PCH gets signal that there is no discrete card present
Second step: remove power from GPU via removing coil
Third step : check lvds connector
Make sure clock and data is feeder to pch only
Make sure backlight control and display on is controlled via PCH
Fourth step : hdmi cable connection is directly interacted with PCH not GPU
Then PCH will switch display on lvds from GPU
Rapid change in technology.
Vram id or board id
How ?
