Acer 5349 charging problem
  • zmeutz
    • Nov 2016
    • 84
    Acer 5349 charging problem...
    I have an Acer motherboard that start with battery or charger... if the battery it's connected and I connect charger it stay on battery and doesn't detect charger.
    With charger connected if I plug battery it see charger and battery and start charging...
    nothing gets hot...
    Anyone had this problem?
    Thanks!
  • emestee
    • 228
    Re: Acer 5349 charging problem
    It's a typical problem, actually. Something wrong with the charger circuit.
    Please identify the board correctly.
    • zmeutz
      • Nov 2016
      • 84
      board DAOZRLMB6D0 REV: D
      I changed charge almost all mosfet .. and all from charging ...
      now I get ISL95835HRZ ... I search for compatible one to replace this one too...
      • emestee
        • 228
        Stop guessing, debug the circuit.
        • zmeutz
          • Nov 2016
          • 84
          ok, I'll do this ...
          I was asking maybe was someone here with same problem and was able to share solution ...
          thanks!
            • 21875
            I suggest you read the "Laptop battery charging circuit" thread - https://www.badcaps.net/forum/showthread.php?t=90356 .Have you tested PQ26
            • serious_electron
              Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
              by serious_electron
              Hello Everyone!
              I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
              06-28-2025, 02:57 PM
            • Thomasraud
              Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
              by Thomasraud
              i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
              QUOTED
              -It works on charger (without battery connected-only charger)
              -It works on battery (without charger connected-only battery)
              -& it also works when plugged in battery & charger, but it's not charging the battery
              //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
              and..
              QUOTE
              The IC cannot maintain the input current level
              06-28-2022, 06:47 PM
            • CPUFiddler
              Acer Nitro 5 AN515-45 not charging
              by CPUFiddler
              Hi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
              This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
              I've downloaded...
              03-19-2025, 07:44 AM
            • ahmarzo
              Hp laptop charging problem
              by ahmarzo
              Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
              Charging ic is bq737 with voltages on pin no
              1&2 -19v
              34&5 -0v
              6 -2.56 v
              7- 0v
              8&9 -3.15v
              10 -0v
              11 -0.18v
              12 & 13 -13v
              14&15 -0v
              16 -6v
              17;18&19 -13v
              20 - 19v
              Voltages on battery connector are
              1&2. -13v
              3&4 -3.14 v
              5&6 -0v
              8&9 are ground...
              03-20-2025, 05:13 AM
            • ronaldopdias
              Acer Aspire 3 A314. Not Charging.
              by ronaldopdias
              Laptop Model: Acer Aspire 3 A314
              Motherboard Model: DA0Z8EMB8C0 - Model: Z8E
              Charging IC: BQ24780 which I have repalced.
              Issue Description:
              I'm experiencing an issue with the charging system on this laptop. The BQ24780 charging IC is not working as expected. The main problems are:
              1. ACDET is missing (0V):, Reading 0V on the ACDET pin.
              2. ACOK is not present (0V): Is missing as well.
              3. No SMBus signals (SDA and SCL are missing): The SDA and SCL signals for SMBus communication are not present. There is no clock (SCL) or data (SDA) activity on these lines.
              What I Have...
              12-19-2024, 04:15 AM
